That’s about what I plan on running. 18s is kinda just pointless unless you drop to 140kv. Then you’ll see performance improvements (torque n whatnot)
150kv would be just about perfect for me. Sadly I don’t know of any 6374 ~150kv motors.
I have 6485s 151kv
Do they fit on 220mm BN hangers with m1 drives. I was under the impression 6374 is as much room as I’ve got.
Oh yeah not sure about that
With the old adjustable baseplate they do, otherwise not
I’m pretty sure I have the new adjustable, how do I tell?
I’ve got new style ones.
Can you adjust the old style while they are mounted drop through?
yes
and i’m going to test them if they work fine without said phase filters because they , afaik, no longer work so i don’t have a choice in the say (yes it was repaired)
at 18s
You have to take them off to adjust them, deck is in way of adjustment bolt
Wait the phase filters broke?
And we’re repaired but still don’t work?
i really messed up my esc, popped the AS, fried 4 mosfets, broke the DRV, and broke the phase filter chip
NOT the esc’s fault*
I’m putting it in likely tomorrow and testing it out on my board
it is going to be interesting since my other esc has phase filters
idk if I am going to leave that one alone or will reconfigure both to have no phase filters
How did you break it?
yaaa, what bboybowzer said
this is SC #8 or 9 iirc that i’ve broken, first in a year and a half or so now
What size is the ppm jst on the 60d+? my ppm port seems to have to a jst 3 pins just bigger ?
2.54 pitch
Isn’t it xh vs ph?
are you running like 200 phase amps / side or something?
