lmao
l canāt find the real specs of theses vescās
what does DRV do?
It performs the functions of a few chips in one neat and small package
Some discussion here
based on what i know, regulates voltage and acts as a gate driver to open and close the mosfets
Can I somehow charge a phone from pins on the Stormcore or should I get buck converter and do it from the battery?
āCanā and āshouldā are two different questions. I would get a buck converter.
Swd arenāt I?
Edit: so it appears 5.3 has started bricking my stormcores. Iāve used this same program Iām pretty positive to flash 5.3.
Getting my first VESC - Stormcore tomorrow and what do I have to avoid to not brick it?
60d+ new.
Just donāt go to 5.3. Most folks donāt recommend it. Iāve had use cases where I needed it for function.
This video is from a 4wd setup. Canbus cable and the other stormcore were disconnected
Which program did you use out of curiosity?
Vesctool 3.01 on Mac
LaCroix official stance is to update to 5.3 or else you run the very high risk of your stormcore getting stuck in a half-on/half-off state.
Iām currently 3/5 escs that Iāve flashed to 5.3 being ok ish. The 2 last night were unfortunate
The 100dx has phase filters right?
Can it handle 190kv at 18s?
I wonāt actually be going that fast on a loaded vanguard with 6354s but itās good to know.
Yes, but your motors will be extremely loud. @poastoast is running that setup rn
Good to know. Loud because of the rpm right?
If so that wonāt be an issue since Iāll fall off prior to hearing it.
Just donāt free spin the motors too much
Set your duty cycle limit lower
Fwiw running high voltage in high kv without a crazy gear ratio to compensate for it wonāt give you much of any performance difference. If you were running something like 4:1 on 105s thatās where it helps
Howās 2.78 on 105s sound ![]()
Not exactly going for performance here.
