These boards use the APEX stormcore/unity case
The last of the Version 1 ones IIRC
What mounting pattern does that use?
Old school skate pattern, has accommodations for spring truck adjusters
Love how they keep trying to hinder apex and yet apex continues to adapt everything to be compatible with trampa products
I was more interested in knowing what mounting it had for the stormcore ![]()
Might want one for my future LsSS 4wd
We want to make stuff compatible with as much other stuff as we can, this is better for the end users and better for the environment. Vendor locking serves nobody except the company doing the locking, itâs not good for the community at all. Sure we have a healthy rivalry with another company, but activly designing to make their stuff not compatible isnât great for the end users.
The case has the 4 mounting holes for the stormcore and comes with the bolts to mount the ESC into the enclosure, would be a great option for your build.
Greetings folks. I recently upgraded from a unity running 5.2 fw to a 60D, and noticed that sometimes when I hard brake, the board cuts out for a split second when itâs rolling at like 1km/h. Fortunately itâs close to stopping speed so itâs not lethal, but it threw me off the first time, and I did hard accel and brake during my tests to try to replicate it.
Hereâs my board specs
12s5p P42A bypass discharge,
Stormcore 60D
Turnigy SK3 192kv
16/60 gear ratio
155mm metroboard tyres
Board settings
Motor max 110A
Motor brake -110A
Batt max 150A (75A each side)
Regen -15
Also, I noticed that in order to get similar feel to my unity, I had to increase to 110A motor max, whereas on the unity I was on 100A.
Anyone had a similar issue with the low speed cut off when hard braking?
Are there any faults?
What is your fault timeout set to? Try lowering that to 85ms.
Nope, no faults, Iâll set the fault timeout and see if it still happens.
thatâs much brake powah
@Arch
I just saw the video on your youtube channel talking about the stormcore app for android, were is the apk available for download?
You are mistaken, stormcore app is iOS only.
On the minute 14:20 they talk about the stormcore app and after that they are talk about android I must have misunderstood, my bad⌠![]()
Itâs a very basic UI
If youâre already using Freesk8, Iâd say youâre good and should stay with it
But. But. But. Wasnât android version gonna be released some time in 2021?
Okay thanks for the info⌠
Freesk8 app works alright with Stormcore, but you canât log anything with the stock ble. Doesnât the stormcore app have ride logging?
