Stormcore Android app? Still WIP, but u can use vesctool app instead, it also works.
I would recommend the vesctool app since u r supporting vedder for future development
Yeah you just have to deal with it finding every single device around you too
Canât wait for the dedicated app to come to android.
Vesctool app works fine, but its basically just the vesc tool on mobile. Better ride logs/integrated features would be nice. Metr is still the best solution Iâve found feature wise but kinda makes the internal BLE useless.
Havenât heard any recent mention of Android on Stormcore.
Yea that sucks big time, but thatâs also the only way to find everything. We need a renaming device method real bad
That is my favorite feature
is the stormcore ios app also working for other escs?
or is it just for the stormcore?
KR and thx
This is patched next release
among other exciting changes
Finally!!!
@Deodand since we donât really see you often here. howâs life doing? Still happy at lacroix?
HOLD UP
YOU FIXED THE BLUETOOTH DEVICE HELL ??? When I rename my esc it just goes back to whatever other name
Yup yup, I moved to Sweden and am working on an electric airplane with Vedder for my day job now though.
oooooh, nice!
Dude thats amazing! Can we follow the project somewhere?
Hi guys, I have a 100d stormcore installed on my 11X zero escooter. I modified the original engines by installing the hall sensors.
Can I write here for help with configuration?
Thank you all !
Just make sure you got a 5V and G set up right, the Hall cables donât care whatorder theyâre putnin, donât mess up the Temp cable
if you open up the 100D you can see what goes where iirc
Hey guys, quick question. If the stormcore power button blinks red, what does it mean?
Fault detected
Yikes okay. It happened on a friendâs board so iâm not able to take a look at it now, on his Davega it prompts a few off balanced groups. Hopefully nothing catastrophic.
Hey all,
Whatâs the minimum time you need to press the power switch (button) to turn off the Stormcores?
What are the two BTN pins connected to on the circuit board? Ground and ??? or 5V/3.3V and ???
Thanks!
The button pins connect between a large pullup resistor to battery voltage in and a series of high impedance pathways to feed that signal to both the microcontroller and a high side mosfet driver. Pressing the button in pulls that high and flips on a precharge pathway, from there the mcu takes over. For off I think I have it programmed for 1.5 seconds or so but this can be modified in code.
If you want to just turn the unit on you can also simply bypass the switch and feed 5v to the unit. There is also a CAN command to turn it off. If you want to go a path besides a button that is the route I would recommend taking. It was a bit tricky to get the power switch to work well across the range of possible input voltages.
