If you’re on Android just move that file into a new folder, also make sure you allow permissions for the app to access your files then restart the app (close it in the background) and things should start appearing.
EDIT: The permission prompt should pop up when you want to choose custom file for the firmware
sofu
August 21, 2020, 12:27am
#2605
You mean for web? That setting has yet to be built in. Web is in heavy beta rn
Flasher
August 21, 2020, 12:29am
#2606
@sofu yes on web
I use one of my wife’s iPhones for the app and then send the ride to my android through messenger.
kook
August 21, 2020, 12:34am
#2607
sometimes it pays to think about what you’re doing before you actually do it… you can get 35° to 55° baseplates
mmaner
August 21, 2020, 12:51am
#2608
malJohann:
Farkin’ell
I need that in a t-shirt.
rey8801
August 21, 2020, 2:15am
#2609
Well thanks! I guess I should have insist more and not just rely on what people say. Happy it works for you.
DJ4se
August 21, 2020, 2:29am
#2610
That’s exactly what I did
kook
August 21, 2020, 2:30am
#2611
faaaaaaaaaaaaaaak
I’m like @k00kofthefuture
Grievor
August 21, 2020, 2:51am
#2612
Works beautifully now. Thanks for the update.
JoeyZ5
August 21, 2020, 3:29am
#2613
So can I plug a Metr into the 8 pin UART port and a VX1 into the 4 pin one? Or should I just use PWM for the VX1?
mmaner
split this topic
August 21, 2020, 1:33pm
#2614
13 posts were merged into an existing topic: Derail Jail 2020_Summer
Arch
August 21, 2020, 5:22pm
#2615
Yes it is. Sender has a bunch of them. Will update the website soon to process payments for them.
you can’t share a uart between two uart devices. so go PPM for the VX1 ( and a wire to B+ for voltage reeading. )
yes usplit is a thing. it’s not recommended for controllers.
EDIT. you weren’t talking about sharing uart… blah.
I think it should work with the two uarts to use both one for vx1 and one for metr. as long as it’s all wired right.
I don’t think he’s sharing the port. But taking about the side port. But I don’t believe the side UART is activated yet. You should be able to use TWO UART devices no? Just not two devices on one UART Port.
Meeep
August 21, 2020, 11:30pm
#2620
Looks sexy af but do my eyes deceive me…? Is that a limited run prototype XL TBDD?
EDness
August 22, 2020, 12:43am
#2621
The heat sink was damn hot after a quick 5 mile test ride.
GJF1
August 22, 2020, 12:52am
#2622
It looks so high is that what mine will look like smh… I got a similar setup.
JoeyZ5
August 22, 2020, 1:01am
#2623
I made a cable for the side UART port so if that doesn’t work I’ll just use the PWM cable until its activated.
