So 3s battry = 11.1v - 6.3v (kweld needs at 1500a)= 4.8v
So as stated above you 4.8v over voltage will alow 4.8*0.67=3.216Mohm reactance inside the battry /3= 1.072Mohm per S to stay in the optimum range of the Kweld
In the video each cell had a internal resistance of 6-44Mohm well above the recommended 1.072Mohm per a cell in a 3s configuration
2 options to rectify this higher voltage or lower internal resistance
Say you used a 3s6p each cell is 6Mohm resistance (best battry internal resistance I saw in the video if I used the 44Mohm it will be way worse)
1s 6p (1/6Mohm battry resitance)*6Series=1Mohm
1/1=1Mohm battry resistance in the parallel group.
3s6p 1(parallel Group battry Mohm resistance)*3(number of series)=3
So a 3s6p should work if you got only the most healthiest 6milly ohm cells and no bad ones. To put this in to prespective a 30q has a 20mohm internal resistance so each cell is aprox 3*30q in capacity and discharge.
Unless I’m screwing some thing up the 1000a burst rating is well over estimated and is closer to 250a burst rating
