Not sure if Iâm understanding it fully, but could a C clip help? It seems like a vibration/weird dynamic load problem rather than a sustained force, thatâs why I went to C clip. I think what Iâm not getting is how it pulled through from the other side where the ânormalâ pulley was mounted
Edit: never mind sorry, I forgot itâs not a continuous axle but the plate bolts to the motor and also the new axle. On the 12mm axle turned down, what about a shoulder bolt? That should have a head that could be used in @Bavioze 's drawing and a length thatâs useful as an axle. I believe itâs what boardnamics does
I might attempt this, and use a M12 bolt, turned down to that shape. The shoulder will prevent it from coming out. As for prevention of having the shaft spinning, I could do a dutch pin again, or maybe even two for redundancy.
I found a 12.9 grade M12 bolt on aliexpress, might go with this
Right, but then i would need to machine/file the hole of my plate to the square. Not confident in making it concentric haha.
@b264 no worries, i donât need to push the mounts closer to the middle anymore, if i am going with this single motor dual drive, they have to be pushed closer to the tip of the axle.
Another dutch pin perpendicular to that one, coming in from the edge, on the other side of the shaft. Then fill in behind the pin with a little epoxy so it can never come out.
Well JB Weld but I might just prefer a softer epoxy like West System 650. JB Weld 8265S can actually crack itâs so hard. WS650 is slightly more ductile. (But still hardly ductile at all)
Itâs not applicable here, but my solution to this on a single-sided shaft was to drill and tap the shaft and put a bolt & washer in it, to mechanically keep the dutch pin in there, and also keep the shaft from sliding out.
When hand spinning the side where the motor isnt connected to, the can doesnt spin, same on the other side. But when throttling, both wheels and the can spins. Whatâs this sorcery? Is this all in some bearing magic that i dont know about? I do not see any differential gear as well
I think you need a coiled or slotted spring pin horizontally instead of a vertical Dutch pin.
Coiled should be best to hold up against esk8 vibrations. Maybe once itâs seated you could even follow up w/a tap & grub screw so it canât back out
