Why? You ask? Why not I have the parts…
The motors run fine on 30amps but I doubt the battery will support that amp load… No fucks given…
I was at first going to meld 2 double crappy LingYi ESCs but thats’ not going to work unless someone can give me a pinout of the canbus port
Or I magically meld two remotes into one remote… Even I think this is sketchy…
So Neo/Jed/Jeff boxes
Haha well that won’t be happening…
So I begin to accumulate BoxesOfFoc… The pickings are getting pretty fucking thin lately…
But from out of the heavens two Jedbox v6 from the test phase land in my lap…
So now I’ve got 2 FocBoxes hardware 4, and two Jedboxes running hardware 6…
I “think” I’ll run canbus cables between the FocBoxes and another cancable between the Jedboxes with dual receivers one on front axle and one receiver on the rear axle…
Thanks… I’ll look at this as your blessing!
I wanna run same firmware everywhere and same hardware on same axles… Split PPM To possibly mitigate The hardware difference… Id almost like to run 4 receivers but that sounds k00ky even to me…
If’n you wanna jump ahead of the class, take a peek at my Following in steps of Carvon thread…
These crap hubs converted to direct-drives make a cameo appearance…
Agreed…
I’m even going to run this crap battery top mount in a non-fireproof molle bag strapped to the board with custom stretchy tie down thingies… No fucks given…
The board I wanted to use was a flexy-flyer super fun board a friend in HB pressed for me…
Unfortunately it got ran over by a car, and crushed when I was down-hilling freeskating my first set of @moestooge three links… Faaak…
So plan B… Crappy amazon board… Or maybe wouldbuy me favor eith my buddy and he can press me another …
I faaking hate opening up a prebuilt battery and seeing the little shop of horrors that awaits me… we all know it will be grim
It’s probably got a 30amp limited BMS with crappy cells and even crappier construction…
But sometimes you gotta work thru the pain!
Where’s that guy @kevingraehl ? Hey you have any 10s Daly BMS’s
I guess i should check his thread… My Daly 10s BMS’s have been shanghaied in HongKong for like two months…
