IWonder Pulley for HUB motors
Ridden about 5 miles. As far as actual turning and such, I find it’s surprisingly not too impacted by the larger wheelbase on the rear trucks. Turn radius, as well as turning at lower speeds, are impacted negatively however. Ride is evidently vastly improved coming from the 97mm sleeves.
Overall, I quite enjoy them and feel they are useful in certain applications apart from their obvious sketchiness. Not sure if I can ever feel comfortable riding on a wheel supported only by screws which previously held the motor cap on… My brother and I are quite light, which must help, however I can’t see heavier riders utilizing this.
You should push them and break them, for people’s sake :wink:
Good thing is like someone mentioned before if they break off they just hop right back onto the stock sleeves
Which are not holding because bolts that hold the adapters also hold the stock sleeves…! :fearful:
Yep.
That looks just as ridiculous as I thought it would :joy:
Damn, I’m like the hub guy, if you need serious testing :smiley:
Why did you not leave the original front wheels in place like you have done in the back to have the same length in the front and back?
I plan on testing with a Backfire Mini soon too.
Did you test?
Now wait a second … (i) how do I get the front cloud wheels on on top of the street wheels or (ii) am I supposed to ride like that or (iii) do I have to remove the street wheels in the front and replace them with the icloud wheels, or (iv) do I have get a wider axle for the front first?? Help @Hide !
Okay, I am getting it (may be) … the thing is actually supposed to be like that; I guess I should have read more carefully above
Regardless if this idea works or not it looks absolutely ridiculous lmao
Just recharging now … will go check. Don’t care about looks, but how this setup will get me (illegally) to work. Road is mostly not good, a lot of bumps. Non-asphalte trails and bridges to cross.
Where’d you end up buying the cloudwheels from?
Bought them from here > https://www.icloudwheel.com/collections/diy-accessories/products/wheel-pulley-kits-for-cloudwheel-discovery-version
Delivery was suprisingly quick. Less than a week, I think.
congratulations, your board now looks like dick and balls
you could throw a single @Boardnamics 220/270 hanger on the front hahah.
That narrower front hanger… totally a high speed downhill setup.
Just went for a night ride … it may look absolutely ridiculous, but I am fucking impressed! For my mixed terrain riding this is a huge improvement!
Overall, the board is heavier now, I would guess something like 8 kg up from 6 kg, but it is totally worth it in my case.
I get a little wheel bite on tight turns in the front and I will have to add additional risers, but overall this is it!! Ah yes, and brakes are less strong downhill, but still okay (my weight is around 100 kg), Uphill performance top!
For mixed terrain, much much better than the original setup that the Backfire Mini comes with.
Why? Because the M4 screws that fix the adapter to the hub motors will brake?
That’s the concern - and it makes sense to be concerned about haha
I will ride it for a couple of months and report back … I hope I can :crazy_face:
