Debatable I have a box of dead fliphite gear
And if it fails closed? Do you have to solder a jumper bypass or something?
After the above, I assume
I wouldnât use one without building in a loop key as well.
But thats just me.
Itâs not just you
Whatâs the difference between failing open/closed?
Fail closed = always on
fail open = never turns on
Ah, i had it backwards. When mechanical valves fail open, theyâre âcommunicatingâ. Fail closed is off.
ah the classic semi conductor
Yeah I figured so much. Should have used better logic when I asked my question⌠what happens while riding if they fail open/closed is what I ment⌠Or when do they usually fail? Under use or at startup?
Blame it on my finglish
They fail usually at startup and typically not in the middle of a ride.
If it fails open, well you simply lose power and coast.
If it fails closed, then it acts as a wire.
But you could just bridge it if it fails, no?
Not if it fails open, it needs some modifications then
Damn. Complicated stuff?
I donât really know tbh
Lol. Nice answer
I just know it needs some modifications, not exactly what
Put a piece of nickle strip in there and 2 drops of mystery oil and watch that sum bish run like a spotted ape.
Whoa dude, no need to drag some great American pastimes through the mud. He is what he is, itâs not the blow.
Maybe I missed it though, the xmatic app on ios just needs a Bluetooth connection, why couldnât it be used with bkb unity? Is unity not configured with the same vesc tool I use now with other esc?
