This is the absolute max instant power a sherman default battery can pull from full charge
Pretty damn impressive
where do you get 150amps from?
i am seeing 3.2kw on the site i am looking at
also 3kā¦ for that price iāll take a lacroix please
it looks a beast but at that price i would want a board
if i can find a frame for itā¦ it would be an interesting project to try
seems like you would need the trampa 75/300 or 100/250 vesc
im pretty sure the stock Sherman doesnāt go above ~4-5kw or something. Acceleration is the one thing boards are the king as far as I know.
4.2v max charge, 24 series and 15Ax10 battery current rating. Theyāre 10A continuous 15A with thermal limit panasonic cells. Too lazy to search the model now
Under max loads most cells sagg to around 3,6V or something. But the Limit in this case is probably the Controller and motor.
ah didnt know it was 10p or the amount of amps
the stock is limited to 4kw as far as i can see
also most controllers are not handling anywhere near 14kw
even the trampa ones can max at 20kw and those are absolute beasts
Iām just teasing dude, donāt get your knickers in a knot
and you know that howā¦
My spidey senses were tingling
so quick update
i went on ride with @athrx and another guy
(your board is awesome man check out his build thread)
and i had a slight issue with one of my motors braking when i attempted to accelerate. @Athrx helped me fix it and we turned on traction control and reduced the sensored erpm and it seems to get along fine now
i tried his mountainboard for a brief time and i found those bindings awesome (mbs f5) is there anything similar for regular longboards?
thats all for now and thanks for reading
Maybe those half bindings that attach to the baseplate bolts?
Just donāt think you can actually jump with those. Theyāre more so you can grip the deck in turns better
thats what i want
Only see white unfortunately
Few guys on carve use similar things, worth asking i think
k will talk but it seems they dont really go in the position that i put my feet at
if anyone has recommendations then please say
Glad you have some helping hands around from @Athrxā¦
Im always afraid you burn your house down jkjk
awesome guy and a frikkin esk8 genius
so much harder then it sounds
Thatās because your deck is waaay out of the regular deck sizes. You can always just drill new holes in the deck but be very careful not to let any bolt stick out the other side or shorts will happen
