@magharees Have you received your tracking number by email? Order completed just indicates that I have finished processing your order and that it has been shipped out.
Edit: I just checked your tracking number, it is currently in transit, it has already arrived to your country. Let me know if you want me to PM it to you.
Glad it arrived safely, seeing how things are unstable around the world
Indeed, I plan on making an enclosure for the iLogger and release the stl file, I’m also going to release the stl file for the upcoming (still unannounced ) Infinity remote, which is going to be compatible with the iLogger.
Yes definitely, iLogger has CAN driver built-in, and support for LiteBMS, DieBieMS as well as other standard smart BMSs is planned.
This week I’m going to release the first firmware version that supports LiteBMS and DieBieMS, if anyone has one of those and wants to be an early tester let me know.
Is there any way to customise the live data on the chart in the app?
Regarding your last post, if I can do any testing with LLT smart BMSs, let me know.
I have 3 bluetooth modules (unity, LLT one and yours) in there now, want to reduce it to 1 if possible
The live data could let me get rid of the unity standard one and the latter the BMSs one.
Hey man, what logging should I provide to look into the (almost general) android 10 bug?
I’ll try to be as complete as possible.
Basically my android 8 phone detects 2 can devices on the unity and does things pretty properly (also showing the dual logging tab) while my Android 10 is just detecting 1 can device and for some reason between rides the time/date reverts to 1980 (default)
Also it would be nice if the uploaded rides would show up at account level, instead of me having to remember the letters of the ride I want to see.
So far, fun tech to play with, but this is a new build and I want to see the initial data
Try to reproduce the bug then go to settings, tap Debug log, and tap the send button.
That’s coming up very soon, an online account system where you can see all your uploaded logs on a nice dashboard.
Time is synchronized after each power cycle, there are 3 ways iLogger can synchronize its internal timer:
Through a GPS module, this method keeps track of time even after a powercycle.
Everytime you connect to the iLogger from within the app. After a powercycle, simply connect to the module from the app once, and time should stay synchronized, you can disconnect or turn off your phone after that.
Auto synchronizes on Wifi connect.
I’m working on an Add-on custom GPS module that has integrated time keeping capabilities, that should help all iLoggers stay synchronized forever.
That’s perfect, GPS modules have already a built-in battery to keep track of time even when powered off, so if you have that, iLogger is able to fetch time from connected GPS modules on startup and synchronizes automatically. You don’t need to keep it powered on permanently.
