I need help please
sounds like good sex advice
Yeah that is good advice, to be fair I started my soldering journey with lead free and no flux so I’ve always used it
It’s good for when you’re a dummy like me and forget you recently soldered something and go grab a snack without washing your hands. My practices are really bad in general though. At work, I sometimes eat in the same place I’ve soldered earlier because I don’t really have a dedicated eating space or dedicated soldering space so my office space becomes used for both.
Washing skin with standard soap and water is not enough to remove lead residues.
https://www.cdc.gov/niosh/topics/lead/safe.html
Also this thead is now proper derailed…
Now I am royally confused, I have lead-free solder, and then everyone told me to buy lead solder, so I bought lead solder. I don’t know which to use and I don’t to get lead contamination.
That sounds like operator error while eating
Use leaded. Unless you’re soldering every day the amount of contamination will be minimal. I don’t even touch the solder itself while soldering since it’s in one of those tube holder things.
Use the leaded solder. That CDC stuff is probably more for industrial lead use and especially lead powders or dust.
Lead is lead lmao
lead powder would be infinitely more dangerous though.
any tips for soldering with lead?
We have to be careful when quoting research papers. That paper only covers contamination with lead-oxide powder, not metallic lead that we might get on our hands when soldering.
Lead-oxide powder is easily absorbed and using the wrong cleanser can make it worse, as the paper notes. But as I understand it, metallic lead is not easily absorbed through the skin and can be washed off.
It’s no different from lead free, it’s just way easier to work with. It’s very obvious when it transitions from solid to liquid, unlike lead free which sort of looks the same as it’s cooling. It also doesn’t form spikes as much, although my lead free was a Harbor Freight special so it might have just been terrible to begin with.
I don’t think its as harmless as you make it for.
HOT WORK: SOLDERING,
WELDING
  1. Wear appropriate PPE, including safety
    glasses/goggles, disposable gloves, and full-body
    covering, (face shield, respirator as needed).
  2. Always work in well ventilated area or use local
    exhaust ventilation.
  3. Upon completion of lead work, all waste and PPE
    must be disposed of properly, and respirators, if
    used, must be properly cleaned.
Page 2.
Imo using leaded solder was very much trivialized in this and related communities. I’m not telling you guys what to do and such, but it IS dangerous.
$30
I didn’t even hint at it being anything less than a very harmful substance if it gets into your system. I merely stated that we can’t say metallic lead exposure is the same as lead oxide powder exposure.
Welding that involves lead, anything creating lead fumes, or any situation with lead powder, is much, much more dangerous than casual electrical soldering work. And those precautions you listed should be religiously followed.
I AM NOT SAYING THAT CASUAL HOME SOLDERING OF WIRES IS “SAFE”!!
We should be careful how we quantify the risk though. This is metallic lead with minimal skin exposure and no inhalation or ingestion. Not “safe”, but not a very dangerous practice. Avoid touching anything beyond the work bench until hands are thoroughly washed.
Each of us is free to decide how dangerous we personally feel it is and adjust our exposure accordingly.
That document you linked to says this…
Always wash hands after working with lead materials, before leaving the work area, and before eating or drinking.
gloves exist.
i fucking hate soldering, honestly. so i use the lead shit, because its easier, and gloves and masks exist if you think youre doing it enough to be concerned about contamination.
Riiight like you’re going to wear gloves while handling your electronics and manipulating the soldering iron lmao
Same thing applies though, the solution for the lead free is just use a fume extractor and you’re fine.
