Lead free solder that is good, makes excellent joints. Are you just inexperienced at soldering or something?
I’ve never had a problem with lead free + appropriate flux application. If you know what you’re doing, you can make just as good joints; in addition, you don’t have to be touching lead while you’re working with it.
Welp anyways, I am a believer in lead free, works fine for me. Has a higher melting point though so I guess if your soldering iron isn’t strong enough it can be more annoying
This is what I use, it works wonderfully
The real question is, how necessary are fume extractors, leaded or not.
Edit:
After reading some, I will admit it seems the flux and fumes are worse for you with unleaded. However, not harder to solder besides the higher melting point
I started with lead free and I too cannot understand whats so bad about it. Turn your iron up 20° (C) and it behaves EXACTLY like leaded solder. It just has a more matte finish when it solidifies which leads people to think its a cold joint, which is bs most of the time.
leaded is perfectly fine for hobbyist levels of soldering unless you eat that shit
way easier to work with, and often times don’t need to use extra flux
I have been finding myself leaving the flux alone lately. With a little bit of technique and a reasonable amount of flux in the solder, you can definitely get away without using extra flux. It does make some things much easier tho.
I second this. I’ve been soldering for 31 years. FUCK lead-free solder.
Yeah, I can use it. But why? It’s absolute shit and I couldn’t ever recommend it in good faith for anything. It’s literally got no use aside from maybe on spacecraft or if you need to comply with RoHS and/or are mass-producing items for commercial sale. For a one-off custom electric vehicle build, it’s nigh useless IMHO.
I tried unleaded after a butterfinger accident where I knocked my solder station over and had a contamination scare. My experience was that it just needed higher temps and extra flux to work well, but it just made everything more difficult that noobs already have trouble with. I don’t knock anybody for looking out for their health, but you should get comfortable with it on test pieces before doing the real project
