The interface between motor and sleeve is the same but they’re a bit longer and need to be cut down to fit or else add a spacer
i wouldn’t bother with molding then. Just machine the hangers. I don’t have any experience with molding, but id say machining will almost certainly be faster and will probably yield a better resulting part.
i looked at my motor hangers, it seems like not only do i actually need a shorter axle but i also need to somehow thread the spiked axle through the hanger? surely that can’t be machined…
@hummieee how short is the shorter axle?
The axle is cast in the hanger it’s whole length. Machining would be much easier. If u make a design and come up with a way to fix the axle in the machined hanger I’d like to see and if u come up with a design I’ll send u the splined axle. It comes from Grob. Standard Spline Shafts • Cold Rolled in the US Since 1951 | Grob Inc.
U could cut it whatever length. you’d have to tap the new end.
Im not really sure what you’re saying here, but yes threads are machinable in a variety of ways.
can i use 16s on these?
Depends how well the tires deal with the speed and subsequent centrifugal force. The risk is they fly off
oh wat, the motors won’t explode?
The insulation on the magnet wire is the only voltage limit and it does something like 10,000 volts. The bearing speed has a limit but way before then the tires would fly off. Maybe glue the tires on if u plan to do beyond 35mph. I don’t know and I haven’t tested that fast.
context. Further discussion in Derail Jail 2022 even though no [SERIOUS] tag
but surely the gauge of the wire dictates how many amps could be pushed through it safely
Generally people think of epoxy and all adhesives as glue.
@zackoric its 15awg magnet wire in the motor. It can do a lot of current before it gets too hot. Then again “too hot” depends on who u ask and the motor components. Motors use n48sh magnets which are capable of 300f before start losing strength and 640f before permanently lose that strength
The magnet wire is the best and rare 230c rated so good at 230c for 30,000 hours I think it is. How many amps the wire can handle depends on how long those amps are flowing. I set to 100 amp motor and maybe a bit less battery always work fine for me and performs well.
magnets which are capable of 149°C before lose start loosing strength and 338°C before permanently loosing that strength
Losing. ![]()
If ur gunna distinguish between glue and epoxy I think u will be on ur own
An important thing for builders to learn is that epoxy isn’t the same as single-part glues. Nobody is born knowing this, and I wish I’d figured it out sooner. Just trying to help the world.
I generally use two-part polyurethane adhesives as they come with such different properties and duro. Epoxy is often thought of as the strongest but it’s so hard it can be brittle and not ideal for a lot of things and a bit of flex is often best.
I just glued some plastic panel on my gf car that came off and she insisted on epoxy since known as strongest and I was telling her she shouldve used something soft n flexible. It came apart.
Telling those unaware and I know u know ur glues Brian.
I’ve probably used more one-part epoxy than anything else. Heat cured.
I’m looking to make these bad boys more turny, I was thinking about using Boardnamics Split Angle Precision Baseplates and riptide busings to get the job done. Any thoughts?
Also, do you know what pivit cups the current baseplates use? I would like to order some riptide replacements.
@RipTideSports what size cups do Paris trucks use? These use the same size as Paris’
Paris trucks use various ones: RipTide Sports Inc.
