Wanting to sell off a bunch of my parts ive collected as my board decided to die on me while i was riding. As a result of it trying to turn me into a crayola color palette tastefully named “meat crayon”, I’m wanting to start another build, and as a result of not being able to spend less than ramen budget on food, i need money . Located in Houston, TX.
Will add photos on request as its a ton of different items all over my workspace right now haha. Prices are without shipping, and im pretty negotiable on multiple items. Will also trade for battery building services.
There is a ton more in the bin and around my workspace, so if you spot anything that isnt listed, or youre in search of something, just let me know and ill dig around for it.
Boundmotor Octopus Deck, Enclosure. Deck is in good condition, enclosure has some minor scratches on the bottom. Front end cap is modified to fit a power button and charge port cleanly integrated. Has a bioboards heatsink for a spintend ubox currently installed. I’ll even throw in the nicer enclosure mounting hardware I used. $350.
BN270s, 10mm axles. One of them is kinda beat up as it was sanded down to fit some motors on gear drives without rubbing. $70.
Defiant Board Society BN280s w/Xcell 12mm Axle sleeves, axle nuts. Good condition, and a great way to run the nicer wide pneumatic wheel hubs on an RKP setup. $130.
BN220s, 8mm axles. $70.
Trampa fifties hangers. $60.
Trampa fifties baseplates. $50.
Boardnamics adjustable baseplates. $40.
Lacroix hypertruck axles. $20.
Lacroix Hyperrims + 72T pulleys. $250.
Xcell Spyder XT hubs + 62T pulleys $300.
A set of tires. $40.
Evolve 7" AT wheels, 47T+66T pulleys, needs bearings. $80.
Two generic motors and MBS matrix 2 mounts. $80.
A single Lacroix 6389 of unknown KV. $50.
Topmount VESC enclosure. $30 as is condition
Boardnamics M1 helical gear drives w/6355 motors. $200. Functional, but pretty beat up.
Boardnamics M1AT gear drives. May be missing some hardware, gears need some cleaning off of surface rust from sitting in my garage. $100.
Stormcore VESC heatsink. $30.
Trampa bindings. $25.
MBS bindings. $25.
Meepo 10S2P battery, charger. $80.
Eovan GTS Carbon Pro Deck (heavy wear). $80.
Assorted motor pulleys. $5/pair.
TB110 wheels. $80.
Boosted 105 wheels. $80.
Ownboard Zeus Pro battery. P42a, 13S4P, redone connector to XT90-S. May have blown BMS, need to diagnose. $400.
Reacher 7490 179kv motors. Excellent functional condition, a few cosmetic bumps from them being so beefy and hitting some debris. Will include a handful of 20mm wide pulleys for them in too, as theyre annoying to source. $500. Alternatively, id trade them for some reacher 6485 or similar with a bit of cash on the difference.
Images below
