How to update firmware on the Flipsky 75100 & 75200 FOC ESC
Edit : 75100_202
I thought of this myself. Probably flip sky’s “midnight shift”. Lol
Yes, 75_100_V2 at the bottom of that screenshot is the correct firmware for the 75100202
I’m actually considering designing my own controller since 99% of the controllers are unavailable without obscene import costs, to give an idea I would probably have to pay €200 on import costs for a Trampa 100/250 making them €700 each, at that point a Tronic 250 from miniwheels.eu would make more sense if it ever gets in stock again (€450) but we all know Rion/Tronic lead times
Then again i would rather support Frank & Benjamin but they’re on the pricy side especially without Benjamin selling them in Europe themselves, i guess i’ll just donate to the VESC project rather
But this is normal empty box that i sended ?
Yes, that is due to Jaykup’s custom firmware, original firmware is 75_300_R2, but Jaykup customised it for your (and the rest of us’) safety as the original firmware has default of max 300A which is much too high for these controllers, also temperature sensing and voltage measurement is wrong with official firmware, aswell as you don’t have to turn off phase filters with his custom firmware (you need it off with these controllers)
There isn’t an official 75100 from Frank/Benjamin
If you use real VESC firmware the next things aren’t correct:
-temperature measurement
-max limits
-voltage measurement
-phase filter might be turned on again after updating
and probly some other stuff
all of these could seriously ruin your day
so basically; in the future you’ll have to use Jaykup firmware or you have to download 75_300_R2 file yourself and risk breaking stuff in the future
Flipsky 75100 e-bike ,controller gives low amperage at low rpm
system is;
Flipsky 75100 controller
golden motor magic pie 5 - motor (internal controller canceled ,only motor)
firmware 5.3 jaykup
setting; foc ,hall sensor,10ah battery ,26 inç whell
controller gives low amperage at low rpm,as the speed increases, the current increases.
At firmware Although the battery current is 25 amps
at 1-2 km/h 1-2Amper
at 5-6 km /h 3-4 amper battery current
at 10-12 km/h 8-10 amper battery current
at 20-25 km/s 15-18 amper battery current
at 30-35 km/s 19-21 amper battery current
WHY? what is this?
I want a hardstart.
But, it is soft start
I want low rpm full current, full torque.
And battery current must be constant for full throttle
how?
It fixed itself, I can’t understand.
Anyone know if the flipsky can run sensorless motors?
Yeah any VESC will run senseless motors. There are a few control options that can be configured in the software. Sensorless, HFI, VSS, Silent HFI (not tested on this controller) and of course hall sensors/encoders can be selected if the motor supports it.
hey can someone compile a FW tomorrow when Vedder release ver6
I created a pull request to the VESC project. Hopefully it gets approved and pulled in, then it would just be part of the tool.
This has been successfully merged with the VESC project! Once the new firmware 6.0 release is out (new tentative date of 12/7) it will be included in the VESC tool. Anyone who has loaded the custom firmware will be able to update directly.
With the V1, the firmware update will work with custom firmware or the firmware it was shipped with since the hardware name is the same.
With the V2/Aluminum PCB version, the firmware will still need to be loaded manually the first time since it ships with 75_300_R2, and needs to be on 75_100_V2. After that it can be updated in the VESC tool in 6.0 and all future versions.
6.0 also comes with the ability to downgrade firmware directly in the VESC tool. I’ll see if I can get the 5.2 and 5.3 bin files on his site so that option would be available as well.
I’ll update the main post with new instructions once it’s released.
Thanks to all those who helped test and tweak this firmware along the way!
@jaykup congratulations on having your code on VESC sources, it help us a lot!!
In the case anyone needs, I just got Flipsky 75100 working with the AS5047 magnetic encoder, I shared the results and what I had to do, here: youtube com / watch?v=OC0KvdqMl58
And just today, I tested on my EBike and seems perfect, a very soft startup: youtube com / watch?v=EL9Jek3_hDg
Does anyone have the schematic to this Flipsky 75100? or at least know what is the reference schematic??
I wish to use this controller on my EBike but a need a way to make it very low power, to avoid discharging the battery while the EBike is stored possible several months on the garage. Does anyone know a way to put VESC in low power mode?? any MODs to do on VESC to get low power mode??
Nice job on the encoder!
The Flipsky 75100 V1 design is based on ypl’s work. Flipsky bought a controller from him, copied it with some tweaks and re-sold it as their own.
ypl did open source his hardware after he found out, and while it’s not exactly the same as the Flipsky hardware it should be pretty close
https://endless-sphere.com/forums/viewtopic.php?p=1700766
As for the low power mode, newer VESCs use the STM32 to enable a low power mode. You can see this in the VESC MK5 schematic
https://vesc-project.com/node/311
Along with the header file for that hardware on how it’s configured. It uses GPIOC 5
and some code in the .c file to make it all work
An easier option would be to just buy an external anti-spark switch (usually a small PCB with a bank of mosfets), or make a loop key out of an XT90S as long as voltages are below 18s
As of 12/31/2022 my experience is that the zip file in the first with the the 6.0b56 does not work with the latest 6.0 version of the tool and the V202 / Aluminium hardware. So after following the steps to upload the custom file firmware above I went back to the Firmware section in the 6.0 tool and did the following to get it working:
    1. Bootloader Tab → Select Default → Upload Firmware
    1. Included Files tab (this should show Hw: 75_100_V2 if you did the earlier parts correctly) → Select the VESC_default.bin file on the right → Upload Firmware
After it restarted I had no more errors about motor deserialization, etc. Jaykup referenced this situation if you scroll up a few posts but it looks like he hasn’t updated the instructions in the first post just yet. If you have the 202 hardware version we still have to manually update the firmware because the out of the box hardware name is 75_300_R2 which is wrong. Manually updating it fixes the name to the correct 75_100_V2.
Glad you were able to get it working and thanks for creating those instructions. They are correct.
The deserialization error is due to updates made to the VESC Tool’s configuration code after that 6.0 beta 56 version was compiled. A more descriptive error text would be “Unable to read motor configuration from ESC” or “Unexpected motor configuration format, likely due to beta firmware”.
The main post is now fully updated with new instructions, new firmware links, more hardware versions, more ESC specific information, some formatting and a bit of organization.
Hi, I tried updating the firmware on my Flipsky 75100. Just when the update was done the program stopped responding (I did not turn off the power on my board). After a while I closed the program and found that the vesc must have been bricked. My board does not work and i can not connect it with the vesc tool.
Is it possible to reset the vesc or in some way make it work as before? Can I use a swd programmer for this vesc or do I have to buy a new one? Thank you.
Which 75100? Does the 75100 power up? Blue LED? Green LED? Do you have a bluetooth adapter to try it with? When the ESC is off, is the 3.3v to GND shorted? What’s the resistance between all phase combinations?
You might want to download the beta VESC tool from the VESC project website. It has several speed improvements over the 6.00 release, as well as the archive feature that will still allow you to load 6.00 if you’d like.
If nothing on the hardware has failed, you can use a simple ST-LINK V2 to manually flash the firmware. Expand the “ST-LINK over the SWD port” section on the first post.
I bought it quite recently from flipskys website, is that enough for you to tell which one it is? All hardware seem to work properly except for the software in the 75100. Blue LED. I will look into the other things mentioned ty. This is my first build and Im a complete beginner so Im not familiar with any of this just saying.
