I have a DIY spot welder that I made out of microwave transformator.
It worked good enough so I could make battery packs with non-pure nickel strips that I had,
although every few months I had to re-spot the welds since they got ripped out due to vibration
from the cells.
I recently purchased pure nickel strips and tried to spot weld them to a cell but with no any success.
The welds just won’t hold into the battery. I assume I need something more serious for that application.
I got a tip to use a pneumatic spot welder, but they are very expensive. What do you guys use
to achieve strong welds with a pure nickel strip?
Of course, batteries are dangerous so I want to make sure I can make them as safe as possible.
How do you make a proper welder? I’m willing to invest the money, but not to go super crazy with it.
Actually steel is significantly easier to weld than nickel (ask me how I know loool), this is why OP is having issues I guess, welds are not powerful enough for nickel.
I am. This is how I know all about welding steel.
I spot weld with the boss level custom spot welder, I have control over pulse length and number of pulses etc
Thats weird since nickel has better thermal conductivity then steel and a lower melting point. Makes 0 sense. Any chance your steel was nickel plated ?
as above its not about the thermal conductivity or melting point. Have you ever noticed its easier to weld a nickel strip to a cell than it is to another nickel strip?
In my head I believe the more conductive a material gets the further the spot weld is spread thus leading to a less focused weld meaning you need more amps the more conductive you get.
what cells u been welding? Not sure how the pole materials differ between cells but cells ive gone through are the 30Qs, 35E, LG HG2s, 25R and and some panasonics i can remember the name of. Always felt like nickel to nickel was easier
I can back that up that nickel plated steel is more easy to weld. Not on physics thou.
But my sunkko did pretty good welds with nickel plated steel taps. Once I used pure nickel strips I could easy pop up the welded nickel from the cell. Same thickness of material, same settings on the welder.
