Herringbone Gears Avio MK2 Gear Drive
Tbh, for the speed demons, perhaps i can make adapter for an 8" or 7" wheel that uses an 8mm bearing (if anyone can point me to a compatible wheel?).
Is that something you guys might want? Or will different sized pinions be preferred?
Different size pinions would def be preferred, that’s the only thing that kept me from buying your drivešŸ˜” id love to pick up this new one cuz I love the haggy trucks I have. Just need lower gearing
Actually top speed isn’t that impressive with 170kv. I think like 31mph? And I have excessively good torque. If you’re gearing down more I have to gear up more. 220kv looks a pain though, so I’ll badger you for pinion :slight_smile:
I’d definitely like to keep your gears for my raceboard(s) and I don’t foresee myself putting anything larger than Haggy wheels on those boards so the larger pinion is an item of intrigue
Definitely pinion :ok_hand:
I definitely use definitely too often
Guess i’ll be looking into the largest pinion compatible with the existing drive (:
Yessssss! What about for the original spur gear drive?
Possibly, but i’m not sure if anyone would even want straight cut teeth after trying the herringbone gears tbh.
I want both… and options for both :wink:
what is this? @Linny
I’ll try my best. haha.
Idk it’s new, apparently you can react to a post with emojis now
Love you.
Please don’t ask.
awesome. i can add a poop on all your posts now.
Umm yes! I love the screamers!
The louder the better
I thought so too but these guys scare me. Like I’m breaking the sound barrier and everything’s gonna shatter. :slight_smile:
Pooping on my posts is redundant.
Yet to try mine out, too many other things in the queue.
