I assembled Kahua trucks, Avio Mk2, Haggy 6374s, and Bergmeisters today. Everything fit together cleanly and easily. Great instructional video. I have to admit, when it arrived the number of parts in the box was intimidating but it didn’t take long at all to assemble.
It will be a while before I complete this build and ride on them but so far I am very happy with my purchase.
Did anyone get TB 6380’s working with these? The set I ordered had the motor gear wiggle on it for both motors. About 1mm of tolerance difference. Really don’t want to have to red loctite the gear on… , Timo provided a 6370’s that fit, but really wanted to use these. Also, what did you guys do to prevent scratches on it? After a single day of going over small potholes/normal riding the 3D printed protectors ripped off.
Butane torch will work and it’s fairly cheap. Heat the shaft up a little ( about 15secs ), to melt the loctite, and when it’s hot, use a pair of pliers to gently wiggle the key loose.
Like @avX mentions, get a big torch, not one of those small creme brulee kitchen ones. Heat it up on the high setting untill you see smoke appearing. Maybe some types of loctite dont produce smoke, but heat it at least 20 seconds from my experience. Then immediately take an old towel or cloth, which is folded a few time on itself, wrap it around the gear and pull it of. Once you’ve seen magic smoke it should be fairly easy to pull off in a rotating motion.
I think ABS will hold up pretty well, especially since the bolts are taking most of the force and not the plastic, but I’m also not an engineer so who knows, lol
