1: does motor detection run successfully on that motor? sometime its successfully, sometime not but always after detection its not work forward and back
2: is it difficult to turn when connected to the ESC? no
3: is it difficult to turn when not connected to the ESC? no
4: if you spin it by hand pretty hard and fast does it feel like there comes a point where it just kind of stops itself from turning like it builds in resistance? no
If you leave everything else the same, but change which side the motors are connected to — connect the left motor to the right ESC, and the right motor to the left ESC — does it change which motor doesn’t work?
In case you didn’t notice. He seems to believe his TORQUE BOARDS drives have a problem and he’s not super happy about TORQUE BOARDS customer service so people are trying to help him troubleshoot why one of his TORQUE BOARDS drive isn’t working.
I’ve never setup an FSESC dual, I assume it’s just like two singles just CAN on the PCB, so setup is required for both master and slave individually… is that correct?
Dexter would otherwise be providing this support for a product that ultimately seems probably isn’t an issue with his product but some other companies product. Maybe the topic can be split to a more appropriate thread at this point…
And customer service definitely includes faulty products… that’s one of the main reasons I’d reach out to any company for customer service… help with a faulty product.
But is it the SAME motor that doesn’t work, or a DIFFERENT motor?
I don’t think you are listening or want to help yourself. I’ve asked this important question twice now, and you evade the answer both times. I feel like you just want to blame someone, instead of working toward finding the cause of the problem. If that’s the case, you are just wasting our time here. You must read. And in order to be helped, you must be willing to help yourself. Don’t worry about being able to, we can help with that. But only you can be willing to.
I will ask a third time:
