Hi,
as some of you might already know some of our HB92 decks have cracked/de-laminated.
I have heard of 5 issues by now. Last week I visited my parents in Spain and we finally got to talk with the guys that press/cnc the decks (emailing does not work very well with them).
Possible de-lamination causes:
- Stacked pressing of too many decks:
The glue used in our decks catalyzes with heat when pressed in a heated metallic mold. The issue is that the decks stacked at the ends heat-up/harden much faster, thus preventing the heat propagation to the rest of the stacked decks in the center. They were in a hurry whilst producing them so they could not even confirm us how many they stacked.
- Single sided gluing:
By norm the veneers used in wooden pieces (they do a lot of furniture pieces) are glued in a machine, and the glue is applied on both sides. Our deck veneers are too big for the gluing machine, so they glue was applied by a worker manually, and apparently they applied it only to one side. This potentially may have caused spots without glue.
- Design change (Theory for now, not confirmed):
Lastly, it is possible that the design change weakened the strength of the deck to some extent: we widened the channels by 6mm and the outer chamfer angle was slightly steeper this time around, consequently leaving less wood to support the rider weight/abuse. The prototype sample I tested at home withstood my weight and hard jumping fine, but I weigh ~70kg. Jens (NoWind) has that deck right now, he told me that he intended to use brackets so we sent him the proto deck to be safer (he ordered one after we heard of the first cracked deck). I asked them to make me another sample just to be sure, I’ll report back as soon as I get it.
@NoWind have you tested the deck? with brackets too?
Future of HAYA:
I would like to openly apology, I am sincerely sorry for all V2 HB92 owners
. We do not know how many boards were affected, so we encourage you to test the strength and report back (we already sent an email after hearing of the first incident), don’t be afraid and test it as hard as you want. Naturally all cracked decks will be refunded instantly.
We try to be completely open and we are sure that something like this will not happen again. It is quite a hard hit for us, but we will try to learn from our (even if they are indirect) mistakes.
We will not do any pre-order runs anymore, it creates stress, decisions get rushed and it potentially induces errors/mistakes. We will only sell decks when we have them in stock (if there is still a demand for them) and we will take our time to test each batch/design iteration properly. We’ll also QC all decks from now on.
Thanks for reading, If anything is still not clear please ask here or PM me.
Best, Mathias
Note: HB83 decks are not affected by the gluing issue. Neither are V1 decks.
A refund is what it is, my components are built into this deck. I love this deck. If you make more I will surely purchase, it’s just so clean and simple. For now I guess I’ll work on transferring components back to my previous build.
very sorry to hear this
