It’s been awhile since my last post. Sorry for that, regulations in Norway now are the worst.
I have an issue with the diy Torqueboard motors, the hall sensor wires are tornt off from the hall sensor board inside the TB 6374 190kv motor. What do i do ? I am skilled in soldering, so if I am told how I can solder on new cables and such.
Cheers Marius
Thanks for quick reply b264
Its a street build with dual motors, I took it for a ride now with only one motor, and to my surprise it was almost as fast as with 2 motors even uphill.
I bought some equipment to battle harden the motors but need to fix hall sensor board first
Have you tried HFI yet? Some motors work great with it, some not as much. There’s also sometimes a very involved tuning process. But it can eliminate the need for sensor.
I second this as the same thing happened on my hub motors so I just removed the broken off PCB and left everything else the same. It worked the same as before but with a little extra noise that was pretty quiet. You could buy new hall sensor chips and try to still use that pcb but it isn’t worth the effort to do that IMO.
With a VESC there are way more options for you to use that make using sensors not needed too as b264 already mentioned.
Ok cool thanks, but now I have a dual setup with one motor running perfectly sensored and one completely in the dark, sensor wise. Is that gonna cause any issues ?
If an ESC runs fine like that than I’m sure a VESC can handle it too. (plus @b264 said it is fine already) my hub motor board has been running like that for several months currently
