General Questions Thread 2025
Yep I tried all those files, definitely need to make sure I check all the cords I have. I have it plugged into a 50v battery so should be good voltage?
And I had no idea about the Bluetooth thing, will definitely give that a try.
With all the issue you’ve been having with Spintend prob better to buy a new controller tbh. :rofl:
I couldn’t connect my vx4 pro to regular vx4 receiver. Would love to use them interchangeably but couldn’t get it to work.
I have some of their files downloaded that I can send you. Uploading firmware would be my next step in your situation. Anyone disagree?
Hi guys. I’ve been thinking about a project I want to do, but I’m stuck on the naming scheme (serious).
I have a 2000km Pivot GT and I wanna gut and upgrade every part except for the deck and battery.
If I do this, would it still be called a 'ā€œPivot GTā€? Or would it be something else entirely??
I’ve been thinking about this for a few days. One last planning-step hurdle…
Pivot GT-R? R stands for revision?
I gottttt ittttt!
It’s connected and I’ve ran motor detection and the puck is paired, but I can’t get it to actually work. It’s on PPM, current with smart reverse on both sides, but it won’t give an actual output just make sound.
It feels like there’s so many of y’all with pucks as your primary remote, anybody have advice?
Did you calibrate the remote?
Get pucked
Not really sure what that means, I did what I usually do with a a vx4, is the process different with a PPM remote?
Naw, process is the same. You calibrated the puck on mode 3?
get a gb remote :wink:
If you send one out to test heck yeah! Otherwise it doesn’t make sense for me for now :confused:
Why the heck is it doing this. It’s on PPM with smart reverse but the smart reverse doesn’t even work.
In that video are you throttling foward or backward? Cause it looks like you’re throttling foward…? Unless you have the throttle backward?
Is throttling forward wrong? Yeah I was, and the reverse button wasn’t on.
Glad to know I’m not the only one. I just didn’t want to open my board up if the remote was under the seat of someone’s truck. Adding a lot of extra water proofing makes it harder to get in my board
I also am not a huge fan of the pro version since I can’t get mine to swap to the simple screen. I don’t need all the extra info for my board
