Just from the looks motor itself looks good. I dont see any black stuff or anything burned. Will try your method in a bit. Should I test something else while its opened? Also the stator size is 41mm. I think maytechs I had before were 37mm or something like that.
So I’ve just tested the motor with your method and they performed just as you described. Windings look intact, magnets look brand new (rode it once) What else can I look for? Or have they survived?
So it passed all the test with flying colours. The drill test (02.3 in all the combinations)the wires test all of the steps described in the article. Now for the sensor part. How do I test that? Just look for shorts?
Um, just check for varying resistance when approached with a magnet? The good news is that you dont need sensors to run so atleast you still have motors!
At least something! The vesc I kinda resoonding. I hooked it up to the PC. What can I do to reset the DRV or reset all the values previously programmed on it. How can I look for errors? “Faults” does nothing.
Yeah what @Zach said. I would recommend sensorless anyway because it’s less stuff to fail and it’s less stuff to set up, and it’s less variables to troubleshoot. Just sometimes you might get cogging at exactly 0.00km/h but at any other speed it’s totally fine.
So it looks like your problem is only the ESC. That’s good news
dayyummm that sucksssss
Flipsky fsesc are total garbage. Ive had nothing but problems with them. Doesn’t matter if it’s their single 6.6 or dual 6.6 mini. They all suck, I sent my 6.6 mini back to them almost 2 weeks ago and yesterday I get a message asking for the tracking number, which I sent to them 2 weeks ago and they responded saying they got it. Im attempting a charge back via credit card as the customer service is a joke.
I’m trying to get info from Flipsky. They had been pretty bad during those 4 days lol. They keep asking more questions (which is good) but not answering any of mine.
I hope it’s good news. I got red flashing light on my ESC I’m guessing that indicates some kind of error? I also wonder if I can somehow reset the whole ESC. Do you have an idea of what this option does? Pic below
DRV8301 Reset Latched Faults
Sorry man, mine never got the red flash. One side would stop working, I could power cycle it and it would work again. They’ll ask for a video showing the problem. Then want you to send it back to China which isn’t cheap. File a credit card dispute.
How are those bearings that you were testing out for me. Did they ever die on you?
That could be good or bad.
They could be trying to help
They could also be fishing for a reason to say you voided your warranty Although, that’s assuming Flipsky has a warranty is a another big question
I bet I gotta pay shipping.
Worth $20 to have a chance at it getting fixed?
The Maytech 6.8 is well regarded by LHB and I have at least 3 of them, they’re better than any 4.12 hardware and seem to work better than the flipsky alternatives.
1 unit might work great. Would like to know how many work out if 100 units were in use. QC matters.
Thats one of the reasons why Flipsky suck and one of the reasons the focbox was so great.
How many times have you seen somebody complain about quality issues on a focbox.
Recently I’ve noticed a ton of focboxes with burned DRVs and fried IC’s but I think it’s because I’m looking for it. If the 6.8 keep up how they’re doing right now id call the it a VESC6 based focbox replacement. Its not just one unit either, I have 2 builds based on them totalling 3 and LHB has 2 he uses for hubs my buddy has 2 aswell and they don’t suffer the standard problems I’ve had with every other VESC.
It’ll be interesting to see the actual percentage of failures considering how many people use flipsky compared to unities
I see more unity issues if Im honest compared to focbox
