Yeah I’ve definitely lost some of the bigger medium frit chunks. The fine frit looks like it’ll do a better job. Won’t slice my hands or car up either.
It will last a lifetime if it’s applied right ![]()
Thanks for the update. Getting my ducks in a row.
I can’t imagine I’ll apply right this first time. Lol
Ain’t rocket science, you gots it @abusfullofnuns
If you follow the guide it is pretty issue. If you think you added to much wait till it dries and brush it off with a Chip brush.
my recommendation after 1 test and 2 legit jobs is to lay down a heavy coat when its time to frit… frit… and then come over the frit a press it down some…use something the glass wont stick into like a flimsy cutting board from wal mart…
before I lay the first frit securing coat i shake off all the loose frit that didnt initially stick…it wasnt meant to be…
then use a super soft ass bristle brush and super light ass coat of thane for that first coat over the frit…some of the frit will move outta place but you can also lay in another layer of frit in the bald spots…
then continue to repeat… that last 2 boards I got a bit excited and the first sealing coat I hit a lil heavy and it created air bubbles around the frit and drys kinda creamy looking… instead of clear…less is more just more of less
Give it a go. Process is simple, just take some care with it. I used epoxy, and it turned out pretty well. Expect epoxy might be better for locking in the frit than polyurethane.
Pressing it down would have helped a ton. I had a lot of really sharp chunks sticking up.
I.used my hand lightly… Doesnt hurt but looser bits def stick to the hand… I.find.the sharp edges soften after a bit of riding naturally but.you want everything to glue in.nice.n snug
Here is my new custom bamboo deck that I fritted with clear fine frit and epoxy.
VID_302300206_035951_209
Sry for the vertical video, it was an IG story…
premixed the frit about 50/50 fine/medium and applied using polyester resin. The fine size is almost imperceptible as the resin sort of smooths them over.
I hate polyester resin personally. More prone to cracking and toxic AF.
Timing is everything with fine frit. If applied too soon it sinks into the resin and doesn’t do shit. Wait too long and it doesn’t get locked in well enough.
It is an art in and of itself.
@Sender I could def use more practice. Think I’m going to hold onto the poly for experimenting with vac infusion since that seems to be the standard in that application, but agree that epoxy would be much friendlier to work with in a hand layup, regular bagging, or applying frit.
Does @Sender have a guide to skin a deck?
Id really like to refurbish the looks of my Evo and with some cool graphics and maybe transparent frit over
It’s sender science
Nope it is ancient Chinese secret if you ask nice enough and stroke his beard he may tell you.
Lol that’s like a trade secret - I probably wouldn’t write a guide either
That being said, there are other people on here who have done similar things to the skinning process and documented it
Haha, so far the biggest issue is where to get the canvas with the image to epoxy on the deck
Start with this problem.
