hmmmmm thanks… I’ve got the latest ACK app and the latest FW on 2 Unities, and another build with an HM-10 module and I get nada tostada for telemetry on ACK… nada… ex-@surfer-of-dirt and a couple of others experienced the same issue…
I believe there was a post at the builders about specific HM-10 modules that don’t work on Android 8 or 9. It needs to be flashed w a different fw. Let me see if I can dig it up.
I tested with a BT-05 flashed with HM-10 firmware (just like BKB modules). Worked perfect. Scroll down a bit in the thread for more confirmed “it works”
This did not work for me. To be crystal clear, the BT board that comes pre-installed on Unities did not work with ackmaniac app for me. I had to use a add-on BTLE on the UART port, the usual “thing” for non-unity vescs and ackmaniac.
Oh I hadn’t thought about this before, but I’d be very very cautious about any write operations with ackmaniac app and Unity. AFAIK writes are supported with ackmaniac firmware only, which does not run on unity. This means setting changes, mode switching, etc.
ack dumps out a csv file every ride, including gps coords if your phone is compatible. I throw these into a dropboxed folder. So I can do a bunch of analytics with a small effort. Or toss a file into a spreadsheet to do min/avg/max and draw graphs. the csv also logs faults.
Plus, BT05 are like $2 and flashable to HM10. You can almost standardize your data capture.
I hear ya… when I first started racing kwads, I had reams of data from blackbox and tuning… now the flight controllers and software are so good, and I’m way more experienced I tune by sound and feel and NEVER log blackbox anymore…
I have a feeling my esk8ing shall follow that path and I’m just going to ride and not stress about picking the flyshit out of the pepper…
when I start building my race-board I may revisit this and reconsider…
