Dunno yet I’m just not the big wheels kind of guy I think
Yeah, that’s the tradeoff with gear drives and direct drives at the moment. That’s why my next project will be a belt drive with small wheels.
What is decent speed by your standards? 30mph is pretty damn fast. I can tell you a spill at that speeds, you’ll skitter across the ground before rolling to a stop
If you are unsure about speed vs torque in relationship to wheel size, I would recommend going with a belt drive first. That ways, you can play with wheel size and speed/gearing by changing your pulley setup.
That said, I think people tend to lean towards torque instead of speed. With torque, you can give the illusion of speed with sudden acceleration. You can also climb hills pretty decently (a factor determined more of less by torque) at speed.
Once you have that figured out, you should have a good idea of what speed/wheel size you’ll want to then make a decision on DD drives.
What type of board do you ride? I feel with longboards around the 40" area, people tend to like to go with bigger AT wheels and small boards around the 30" go with thane wheels around 100mm
Of course it is!
I’m not looking for high speed, 25mph max is perfect for my needs ![]()
I wasn’t sure about this either at one point. I really liked my ABEC 97s, but the hype about the 110s from @b264 was too much to ignore. They turned out to be the ideal wheel for my eLofty drives. So, so good.
And what are the specs of your board? 56KV +10S ?
Yes, original 58kv drives, 110 wheels and 10s3p.
What max speed?
22.5 mph. Over the limit for my locale, but also fine for me. And no problem propelling my fat ass up inclines.
Thanks BillGordon!
Hi everyone,
Due to there being more delays and unreliable supplier, I have decided to cancel this group buy with crownwheel.
However, I have been in contact with Nathan at @Esk8supply and we have set up a group buy with him over here: Esk8supply direct drive Group Buy of 3-6 people USA (elofty direct drives)
Feel free to continue the discussions there
For all the members in this group buy, I can give you a refund for this group buy. Or if you still want the direct drives, you can join the new group buy and you will be bumped to the top of the signup list.
@mmaner can you close this thread please?
