eBoosted enclosures updates
With the respect, if this enclosures going to be improve later in the future, i have some suggestions.
  • If it possible to add 10mm more depth in electronic compartment to avoid the limitation of ESC that you can shove in there.
  • If it possible to make the vetical surface that drop down from the deck on front and back bracket mounting point to be straight flat 90° instead of angle surface for easily install many kind of panel mount connectors, because this deck and bracket system is perfect for modular quick change multi drivetrain systems.
    I have no experience in design or working with fiber composite material, if i’m upset someone in there, i’m apologize in advance.
    Edit: grammar
Do you have any plans to update the cruiser enclosure for a 10s3p of 21700?
omg, +1 for this. I wish all enclosures had a straight back wall.
Does anybody know if the Vanguard MS 38 enclosure will fit on the boosted stealth deck? If not, what flexy enclosure would work for that deck? @eBoosted
The Stealth deck is wider than the Vanguards. I thiiiiiink the enclosure should fit just fine.
I was thinking so as well but I don’t know if the curves on the end are further or closer together lengthwise. That was my only concern
What enclosure are you talking about? send me the link
This guy right here
Do you need a custom width or length? You can order a custom cat:
The custom depht is way more difficult to archive so that might not be possible
Any plan for a double stack?
Ground clearance could be a big issue on DS
Always depending on bracketst/trucks/wheels. Well, i will buy one for my low-rider ongoing design but would be up for a double stack to adapt for a inter-city-commuter design
If there is enough interested I’ll make a DS version or maybe a MS
I vote for DS. :raising_hand_man:
How much room is there at the ends to inward mount motors? looks a little tight.
Or how easily can a Vanguard 38" enclosure be mounted to a 42" deck for clearance?
There is enough room to mount the motors inwards :slightly_smiling_face:
Guys, I’m making the 2023 roadmap for enmclosures designs.
I wonder what decks would you like enclosure for in 2023?
I vote for the Omakase.
Yes please
Ben’s enclosure is pretty damn good.
