Yes you will need risers with 6"s … TS Sounds interesting 12s12p? Or 18s8p?
bro being narrow in middle limits p count if the enclosure is square if you make an hourglass shaped enclosure you might be able to do 12s12p with a top mount esc.
i know it does. 200mm +5mm abs wall will fit under the middle part (210mm) so this 12s12p will fit but wont take advantage of the wider part. If i try to take advantage of the wider part i guess ill make those p groups differently shaped
Would the Haero Bro be able to get away with only having the enclosure split in two as opposed to 4 segments? I’d imagine you could get creative with your battery layout… possibly able to get away with a 12S 5 or 6 P single stack?
I was seriously considering a single stack for the battery and top-mounted ESC.
Gaaaaaah I want but I just had my deck senderized haha. I guess I have to build a new kaly.
Do it! Do it!
You got anything that would fit on a killshot 40?
@eBoosted any news on the SS Kaly enclosure? Cousin is looking for one because his Kaly one cracked lol
Anyone in the UK want to buy a SS hs11 enclosure?
I can also ship to Europe if needed
for the redember xapham enclosure how did people fit double stack? got p42a and enclosure is no where near tall enough. is it just a really big gasket?
My battery looks like it will be close to fitting, but won’t know until its back with it’s owner.
ah thought it was for yourself
getting @bigben to fit my enclosure and my battery measures around 4.7cm tall and the hole seems to be around 4cm so got a big gasket to add i guess
The Demonseed 42" enclosure is ready, I’m paiting it at the moment, will upload pictures tonight. It took me several weeks more than anticipated, so all scheduled projects had to be pushed behind, I’m tryinig to catch up now.
Bustin Sporster MKIV (with room for BMS and heatsink)
Kaly SS
Kaly DS
Rayne Demonseed 42" SS
Haero Bro DS
Loaded Vanguard 12S 21700
(edited to reflect Kaly SS not yet available)
Another step closer to fulfilling my long range Vanguard dreams.
Wait theres a kaly SS already available? I don’t see one I less your referring to the hs11 one
I could totally be wrong about that one, I was basing this off of a previously predicted roadmap that Alan laid out. @bboybowzer - Is that not the new Kaly enclosure about 12 posts up from here or maybe that is the double-stack?
Double stack is what I see
