Kaly SS is in the works, currently in design process
Haero DS is next right?
Yes. Working on it.
I see the Haero Bro deck is closer to the ground than any regular EMTB, are you guys sure there would be good ground clearance? You might requiere to use risers
Yeah risers will be necessary for sure, but in conjunction with the shorter wheel base mounting option and some risers it will be fiiiiine
@GJF1 did you use risers on the aurum build
Hello Guys, as promised earlier, I present you the Rayne Demonseed 42" enclosure.
I chose to develop this enclosure because of several reasons:
- The deck is widely available
- It’s one of the only enclosures to be able to hold a 14S4P or 12S5P battery pack made with 21700 cells in single stack configuration
- The double drop Demonseed is a beautiful deck, very comfortable with great aesthetics, it has a deep concave to lock your feet at high speeds and aggressive cornering
I hope this new enclosure helps to develop the community even more as, these days, builders are comming up with builds with more range, faster speeds and torquier/power hungry motors but keeping thinner/slimmer profiles for eye-pleassing experience.
The cost of the enclosure is US$ 135 and it can be ordered here:
Duuuuuude
No risers necessary for 7s or 8s and the battery fit perfectly 12s8p… space for 14s8p…
Ground clearance is good but risers can be used for extra security
Hot damn…that is a beauty!
What are the internal dimensions?
Bustin Sportster DS enclosure, pleeeeeeease
most EMB will be 8 or 9 inch wheels -so good ground clearance -is the haero enclosure able to take DS 21700 ? Cheers
@eboosted the demonseed enclosure looks insane. awesome work
any chance a ds will be coming out before i place my order
if ss can fit 12s5p then can ds fit 12s10p
No DS on the roadmap for the Demonseed, if I ever do it, it won’t hold a 12s10p because offset stacks take more width
yeah but hopefully could hold a huge battery in
maybe one day
Will this fit a Spintend Ubox 75/100 controller with those configurations?
That ECS seems to be thicker than a regular p-group of 21700 or a FocBox Unity, I haven’t tried that, so I can’t confirm. Do you have the meassures?
What are your thoughts on that ESC?
Those washers are M5?
Yes M5
