Been on a freeboard once and it scared the shit out of me, but was not on a steep enough hill to get the “break free” point of the caster spring to feel consistent.
Coming from a life of snowboarding, catching an edge on pavement is no bueno.
Good luck man, pretty impressive so far!
that will (UPDATE… NOT)fit the 6007 bearings Actual 35mm od tube needed.
I’m going to cut the bearings I got out of the shit castings that were too big anyways, then I will have to design my own bearing seat.
Still need to figure out how to get suspension fit somewhere, also an endstop. I figure I can print a model to get an idea of how much force is needed. Excited to try the prototype not sure what issues I will have, besides ruining this poor wind turbine slip ring. Not sure if vibration or contaminants will get it first.
Lastly I have not uploaded this project yet so I should do that.
That has been my idea for a while. Kinda a diagonal spring that attaches to the yellow block, I am super tempted to try 4 RC shocks to see how well it would work.
damn I have not looked at ones this nice actually…
Shocks are the same idea just wheel side attachment to the yellow block/idler bolt.
Conserving vertical space is important so switching to the non extended race/set screw locking bearing for the design allows more room for suspension, I am working on an updated version now for the regular roller bearing I linked.
For this prototype I might flip them in so it’s like two giant built in spacer bearings.
Springs are better for long term use and for people to find to build their own, but maybe elastic could work good enough for me, heck maybe I could even use skateboard bushings.
I’d try and fit springs and save the elastic type material in the back pocket.
The bushing idea is interesting. I assume you’re trying to make up for uneven ground which would cause loss of traction(as well as impact absorption ). In which case you need to see how much travel you’ll need to make up for that.
Gotta crash, good luck, I’ll be keeping and eye on it
Shit, guess another back pocket item.
It could come to a point where a couple spring designs would need to be used together to achieve the desired pressure/strength.
This print having the holes lined up with the brush locations gave me an idea that you could 3D print the brush holder to prototype a diy slip ring instead of PCB making. The brushes being glued into the printed base and connected with wires.
This idea allowed by figuring out the right material for said slip ring brushes.
Wonder if anyone learning to CNC could make me some simple copper rings
