Except for the rattling, it sounds like a Tie Fighter, so I would say it’s on the right path
Nice work on this one
Looking very good, cant wait to see more
Will you also implement a cover for the gear drive at some point? must be quite easy for grime to get in atm.
Keep it up
You are right, I need to close the gear drive as seems designed to attract gravel…
Shit man, this is so freaking cool looking. You’re gonna be the coolest guy at the group ride for sure.
In my dream, my boards might be the coolest one at the group ride but in real life, I’m only be the oldest one.
Thanks.
A random stranger suggested designing swing armature for trucks. I thought of you
Looking good maybe you can incorporate a rubber V ring aswel, although thats kinda tricky with the limitation in space and the thin walls.
True.
Next step will be to improve the sealing (but I’m afraid that it will need a better accuracy/quality that my handicraft)
Cool, where are you located?
Europe. SW France. Biarritz.
Maybe get some CNC parts, if you can find something locally and with a bit of luck it wont be that expensive.
Yes, that’s the plan.
This one is only a draft to validate the general design and test few options (specially the electric/electronic integration).
I plan to order water cut/ cnc parts soon to get industrial (vs handycraft) quality
I also considered using other countyside technology…
More seriously, I will try to use a piece of thermoplastic to make the cover to be able to make a “lip” to close better the inner gear
Dual ESCs are your friend.
Have you been looking at the stormcore?
The 60D will be the next big thing for 12S stuff.
Yes, but if dual esc could stay paralell, in reduced space, it will help.
I’m humble regarding electronic, using average performance stuff as it’s enough so far to test my (ongoing) built.
Once the board will be finetuned, I might look for more power (not sure).
looks super fun to ride, would love to try it
