You remember in the movie Big Trouble in Little China when Egg Chen says, “I am the past come back to haunt you!”? Well, the decision to reduce the size of the drive gear is continually haunting me.
Turns out on assembly that the housings are so close to the truck pivot that it will interfere.
There was a point at which I seriously considered going back to the bigger drive gears, but after staring at the problem for a while I realized that maybe with a slight adjustment I could get it to fit…
I powered it up and detected the motors and remote, and it is working, but I can’t charge it until I get the balance leads wired up, and I can’t wire them up until I get one more of the waterproof charge connectors (I switched from 9-pin to 7-pin but I only ordered one to make sure it fit, so now I need to order another).
That arrives early next week.
Tantalizingly close but there’s still a pretty big list
put foam around the top of the battery box
put grip tape on the deck
attach the deck
cut and install deck ends (wood pieces that cover the drops at each end of the deck)
install the volt meter and wire it
wire all the balance leads
make a new balance harness for the charger
charge it
ride it
Well, from the “If It Ain’t One Thing It’s Another” department it turns out that when you attach the balance charger there’s a pretty significant capacitor discharge inrush current, which, of course, blows my balance lead fuses.
In hindsight getting fast-blow wasn’t such a good idea. And erring on the side of caution as we are doing these days I got very lightweight fuses in the first place (500mA).
So the solution is to go to slow blow, and I bumped it up to 1.5A. But now I have to wait for them to come in. But that’s ok, weather’s crap for the next 2 weeks anyway.
Overall not much forward movement:
[ ] put foam around the top of the battery box
[ ] put grip tape on the deck
[ ] attach the deck
[ ] cut and install deck ends (wood pieces that cover the drops at each end of the deck)
[x] install the volt meter and wire it
[x] wire all the balance leads
[x] make a new balance harness for the charger
[ ] charge it
[ ] ride it
Well ok, it’s not completely done, the grip tape is still in the mail, but I can ride it without, so I’m going to take it out for a test run as soon as the sun comes back.
So just to document, here is the foam surrounding the battery tub
[x] put foam around the top of the battery box
[x] attach the deck
[x] cut and install deck ends (wood pieces that cover the drops at each end of the deck)
[x] charge it
[ ] ride it
It’s actually running quite well, but it just doesn’t have enough battery. I can only get a couple of miles on the beach (maybe 5 or 6?) before it poops out. Also salt water is so damn conductive that the loop key port got wet and so when I went to shut it down even after I pulled the loop the volt meter continued to show voltage.
So to fix it would require a waterproof housing for the loop key and about twice as much battery. I think it’s 10S5P of 4500mAh cells. So double that - but that is a significant weight penalty.
And it’s not as fun as you’d think because the way the wheels break away on the sand is super unpredictable, so you can be turning nicely and then out of nowhere the wheels just let go.
So all in all unless you have a really strong passion for running on the sand probably your time is spent on a really nice eMTB upgrade. Like this one (which admittedly isn’t going that well).
On the other hand it turns heads everywhere it goes Here it is on a September 2023 trip
So last week we were out at the coast because weirdly even though it’s October it was 75 and fully sunny so we snuck out for a couple of days.
I spent most of my time with the daily driver on the paved trail but we did get the Sand Runner out for some miles.
However, I noticed during the last ride (probably what made it the last ride) that there was a lot of wobble in one of the front tires. On inspection the bearing mount had snapped and the wheel was bouncing around the bearing.
This isn’t a big deal since sand running is an inherently slow sport, but it needs fixin’. And if I’m going to fix it I might as well take it as an upgrade opportunity.
So on the list for this winter’s upgrade is a couple of things:
I want to go to different tires. The ones I have work, but the weird tread with the bump down the middle of the tire causes it to jump around anytime it finds lines in the sand. For instance, if I ride out, leaving a tread trail in the sand, then ride back and cross that trail it will grab hold and jump into the old trail unless I cross with a significant angle. I’ve crashed once because of this and run off a few times. It’s definitely disconcerting. So I think I’m going to go to bubble tires as we discussed in the original thread. Failing that I might just remove all the tread from these tires and make them plastic slicks.
I’m going to try to go to 4WD, but with 4 smaller motors. Maybe 5055’s. Currently it’s running 2@6374’s but I think I can get into softer sand with all wheels driven.
Probably I’m going to go to enclosed chain drive. While building those gearboxes was fun it was very time consuming and unfortunately even though I’m retired I still probably can’t make enough time to build 4 new ones.
I’ve always complained that the thing is under-battery’d, but adding more batteries to the traditional design will make it too heavy so I’m going to look at a way of putting 2 modular packs together that I can load in the car independently and then snap on to the board at ride time. I’ll likely try to double the range minus the cost of 2 more motors. This also opens up the possibility of sealing LiPo packs into Pelican Cases which overall should be safer than the current setup.
This is a dead-of-winter kind of project so won’t start for a while but I’ll post updates here.
Just for the record, this falls behind the suspension upgrade to the eMTB, which is still bouncing around in the back of my brain as to how I’m going to pull it off.
