Today I inflate my tire with more air and recharged the battery fully. This time I drove the board on stone and got like 75 min out of the battery. I was happily surprised with this result. Because it means if I drove like 5 km/h, I will have 6.25 km of range (4 miles). This fits my expectations! Thank you very much for the tip!
Also I will search for good washers that will fit the bold and the aluminum.
Got my first flat yesterday Gave me a mini heart attack thinking that a cells overpressure protection blew at first
What pressure do you guys run? I loaded up with 3 almost 4bar (max for the tire) but I suspect that its a bit to much for the hose. I haven’t had time to check where it bursted yet.
Alright So I got my 2 hoverboards in. One of them had “samsung” cells, cant tell if they are real yet but the outside said they were. but the voltage was at 20v so some slow charging and the cells are back to normal. and I tested the hoverboard and all seems to work fine. Both of them had the correct motherboard so that was a big bonus. The other battery somehow is completely dead, I measured it at 3v at the plug so I’ll see if I can revive it but if not I’ll just build a new pack. The hoverboard that had a completly dead battery had one of the motor wires unplugged so Idk if that had anything to do with it.
Hi,
New forum member here, but I’ve been closely following onewheel builds on this forum.
A few weeks ago I also started a “Thedirits” build. I went for the Burris tire, as it’s almost impossible to source decently priced 6" tires here, and I wanted a full width (ie. matching the rim width) tire for better stability.
Up to now the build has been going well, I have the full wheel assembly and front/back platforms printed.
(if you are wondering, parts are printed on a 1mm nozzle with .8mm height, hence the rough look)
Now I’m wondering how did you guys deal with the aluminium rails dimensions ? It looks like the original 3d design is imperial units, but the closest we can source in Europe in metric units does not match perfectly. Especially for the rail height : the design accounts for a 38mm tall rail, while the closest we can source here is 40mm height. So there’s a 2mm gap, which is quite visible in Nathan_3Dr88’s picture :
Did you just print the design as-is and live with the gap, or did you modify the design to compensate for the difference (I’m going this route).
The same question goes with the rails width, but in this case the solution is more obvious, cutting the rails to fit width. I will have to go this route anyway, as the rails I ordered are 40x25x3mm. post edited to add pictures
I also use 40mm rails and just let the gap be for now. Would be great with versions for 40mm rails I sadly lack the time to design them atm but should be relatively easy to do
I have finished my DIY onewheel! I found this project in thingiverse and i decided to do it.
After one week of use I feel more comfortable on it, but when I am near a small climb and my inclination decline the OW couldn’t up.
I have read some tips like to:
change the 0 from gyro.
make a diy battery pack 12S2p or 13S2p.
I think with a modification to add a small wheels in front side I can push down more without fear a nosedive. (working on it)
Assuming that I haven’t knowledge about batteries my question is, How I can get more torque on the wheel although I’m moving at a very low speed? It is possible?
I understand that most of these builds rely more or less on re calibrating the gyro for the “balanced” position to be leaning backward. Did you do this ?
I’m also planning on integrating an emergency landing system, still not sure of the best way to do it, it will probably need so adjustments of the STL file.
As you can see I didn’t compensate the gap, but I don’t really care that much about it. I did modify the width of the part for the rail. I used a 40x20x3. If I remember correctly the width of the part is like 1,85 cm or so. I used Fusion 360 to change it to 2 cm.
So I finished up build number one out of two. My friend and I are heading off to college in the fall and decided to make these. My thoughts on it so far. I used a single button but I have crashed already because I slightly lifted my foot off of the pad but the location of the buttons Ideally would be one on your heel side and one on the toe side so when leaning you dont have to worry about accidentally lifting up your foot. Has anyone thought of modding together a pressure sensor that acts like the optical switch? I was thinking of maybe using an arduino to do something along those lines but we will see. As far as the tire go I did get a 13in tire. At first I thought it was too much and difficult to steer but with practice it is totally ridable. and with the extra clearance off of the ground nose diving becuase of the nature of this build seems to be less of a risk. I havent used a gps but it seems like I am able to go over 15mph with the stock battery with this setup. Id love to hear what you guys think!
Here is the one I just finished. I used an old 6.00 x 6" aluminum aircraft wheel that I machined on the lathe to fit the hoverboard wheels. I’m using all of the original HB electronics. It works well so far and I’m just learning to ride it
So I started with using the rubber nipple thing to activate my Onewheel, but I found it to be inconsistent and not very safe because if you lift your foot off of the button at all the result is you falling off and having a sore day. So I sought out to make a pressure pad, similar to what is used on an actual Onewheel. When scrolling through another forum where they make one wheel with pre-made wheels and vesc’s I found that a lot of people were making their own pads with some copper tape and some Velostat which is pressure-sensitive and semi-conductive material. So using info from this youtube video and other places I made a pad that looks like this.
In order to use this, I had to find a way to turn on the leveling with an Arduino. When messing around I found if you short out two of the pins on the octocupler on the sensor board the board would turn on. So I wired up a transistor to the pins and it worked perfectly.
From there I powered an Arduino nano with 5v from the board and wired everything as pictured above.
If you want a schematic and the code I made a Git Hub for this. I did some testing on it today and it is soooo much easier to get onto the board and I feel a lot more confident when riding that it’s not just going to die under my feet haha. I hope this is helpful and don’t be afraid to ask me any questions!
