Well ack seems like a good fall-back point if everything goes crab-wise, so I believe I’ll always have a known good motor-controller that works on ack… But ack, as you know is a dead-end… If I’m to go forward like the rest of the esk8ing hominids nrf is the way, presently!
Im scared to ask - is this one of those situations where buying a MetrPro Unity… vs a a MetrPro is going to make or break the functionality.
Background: Raptors (Since removal of the Stock enertion PCB was the easist and most impactful single change that was ever done) - Im looking to use my WAND with the board.
I tried this with an nrf51822 on 4.12hw, when i try connect in the SWD prog tab it says: ‘‘Could not recognize target’’, any ideas?
~e~ over openocd it worked flawlessly so its not the module.
Why is that?. why NOT pair NRF remotes?
I have a controller from a cheap chinese esc that went wrong and i wanna used with vesc. I should buy a nrf52xx insted for nrf51xx?
Im looking for compatibility, blu config and remote
But I can’t get my vesc to show up in windows vesc tool. In windows settings it shows up as “VESC BLE UART” paired. UUID is paired in my vesc tool.
Any ideas?
