Thanks to Vedder and gang, the latest firmware update fixes the issue I was having with using an NRF51 module using the previously available firmware.
If you have had the issue where you can flash the firmware and then connect but it gives a no firmware read error I believe it will now work for you if you update the firmware again.
I have tested on 4.2 and 5 beta 7
The latest firmware is integrated in the latest 5 beta package, can flash using that vesc tool
You can also upgrade using 4.2 tool, just load it in custom
Nope, it’s nrf like the unity module or metrpro, you can only use NRF with fw 4/5, hm10 modules no longer work
functionality wise, it does the same thing
hmmm, got some catching up to do… I kind of left it in the stage it was working fine. That’s the luxury of having a spare phone dedicated to vesc tool, and usually not connected to internet to avoid force fed updates.
also, super dumb question, what can vesc-tool for android do with an nrf51-equipped esc that can’t be done with a hm10-equipped esc? also, didn’t the vesc firmware already support nrf24 based modules since like forever?
