Yep of course sorry
Curiously, @DavidC has been in your shoes.
I’m pretty sure the only way to connect to that controller is usb. So and st-link or any other normal methods won’t help you.
Is the controller functional on 3.52? If so could you downgrade the other to 3.52 and run it that way?
I ran into a similar issue with that controller I was able to flash the bootloader using vesc tool. I used an old version that was installed on my pc and then stepped up to vesc tool 1.28 firmware 3.65.
That’s what I think too
Downgrading, upgrading, nothing works I’m afraid
One side is stuck at 3.52 the other you can upgrade/downgrade right?
Or did I read that wrong
I was able to upgrade one of them but now they area both locked
One in 4.02, the other one in 3.52 I think
He was probably following this guide
https://docs.google.com/file/d/1g_5D_FVTTBQiIOWBwuRk5pENaWuxIcFF/edit?usp=docslist_api&filetype=mspresentation
Did you see the vendor comment about using fw 3.65?
Which vesc tool are you using?
That guide would just link you to the current version.
Have you tried to load older versions of the vesc tool and flash the bootloader from them and then firmware?
Also that controller times out and shuts off super fast like faster than you can get setup and flash it sometimes. Turning the remote on buys you some time.
I’s it possible the controller is shutting off when you’re flashing the boot loader?
Lots of question
I tried 0.95, 1.06, 1.28, 20.06 and Ackmaniac
Tried upgrading, downgrading
@Arzamenable
Yeah the FW is supposed to stay at 3.65 but only if you want to keep the functionnality theyr are talking about
At least that’s what I understand
Booloader flashing is quite fast and I usually switch on just before I try to flash, so no shutting off should occure (I think it’s 5 min anyway)
For sure, put what ever you want on it, it’s your gear. Sometimes getting back to stock helps when things are fubar, then moving on from there.
Try a different usb cord. I was pulling my hair out over something related and @mccloed recommended a different cord and it worked. I still don’t understand why.
Tried different USB port, different cables, different PCs
BTW I decided to try to install “forbiden” FW when I was convinced it was bricked
I see. Still no dice?
Hi, @DavidF.
I’m having the same problem and Itried useing v1.28 just now and it isn’t even connecting to the vesc anymore!!
Did you manage to find a v1.29? I’ve tried all forums and internet research and couldn’t get it. Please let me know if you were able to fix your VESC.
Thanks in advance!
This works on every board I’ve tried it on:
@BillGordon. Thanks! It’s now connecting! You saved my board… hahaha. Now I just need to make it work with the 3.65 version.
Let me know, as even with Ackmaniac I was not able to fix my issue, I had to buy a new Esc. (and my board is working now
BTW I never found the version 1.29 for PC, looks like it only existed for MAC
