Awesome! Just tested tested a short m5 on either end and it worked like a charm! Ill pick up some 30mm length ones tomorrow.
Iām having a weird issue with my Davega X. I can try and showcase it if needed.
However, it primarily happens when Iām holding the brake, the Davega X screen will start flashing like itās trying to load and keeps doing it until Iām off the brake.
Any ideas?
I havenāt had anything similar reported before. What kind of VESC do you have? Are you able to test the DAVEGA with another VESC?
It could be a cable routing issue. Could it be that something moves slightly in your enclosure and presses against the cable as youāre braking?
Hereās a video. I donāt have another VESC to try it with another. Iām using a unity.
Edit: Ignore the cogging
Also it seems like the remote can control the Davega as well. It just went into settings and when I pulled on the brake it went down the list of settings.
Itās registering the right button-presses. Please try removing the right button and see if the issue goes away.
Edit: Just unplug it. You donāt need to remove it completely.
This just confirms thereās something wrong with the right/down button.
Looks like youāre using the screen as backing plate? Thatās kinda odd. Who knows, maybe itās putting too much pressure on the button and activating it.
Yes, even with removing itās still having issues tho.
What kind of vibrations is that?
Note that buttons are disabled while youāre riding so you can only experience this behavior with some heavy vibrations in standstill. Thatās not a standard use case.
Sensorless motors so I have shaking at low voltage situations.
Is there a way to just have a button lock if thatās the case. Although it doesnāt make sense that if I hold it, it doesnāt have issues. But the moment it touches the plate it has issues.
I unplugged the right button (up arrow) and I no longer have issues. How can I get this repaired?
Edit: Odd, plugged back in and so far so good.
Follow up: Issue happened again. Unplugged right button and then the Davega started entering settings. Removed that button and then the left button started getting triggered. All buttons disconnected now and itās working but obviously I have no way of switching screens now.
Any ideas?
Those vibrations seem pretty heavy and they clearly trigger the buttons. I donāt think getting started in that way is good for your board. You should push to start or if you have bindings you should use HFI.
I can imagine itās probably not, so yeah I kick push. The issue at hand does not go away.
Please see this post.
It shows the Davega cycling while riding under normal conditions.
The new 4.0 installer on windows keeps saying cannot access the specified device, path, or file. You may not have the appropriate permissions to access the item.
Iāve tried it with the USB drivers installed and uninstalled, in My Documents, C:\ Drive and desktop for each, Davega connected and disconnected.
I got it to work, Windows Defender identifies it as a potentially unwanted appā¦
Itās a Python script compiled with pyinstaller. Itās a known issue that anti-virus programs mistakenly identify pyinstaller compiled code as malware. Thereās unfortunately not much that can be done about it.
Iām glad you were able to sort it out.
Does the screen switch when you push the throttle? Thatās the standard idle screen.
