Nice.
Next time do a fillet pass on the corners.
Awesome work guys
Are you able to machine steel?
Those look so badass.
Haha thanks!
I can plasma cut steal!
Awesome! Gonna need your help in a little while getting a big gear done
Haha sick. Lmk, Iâm here!
Sounds good my man! Itâs for my EV conversion and the gear will allow me to actually run the 2 electric motors together, as the transmission currently doesnât allow that
The teeth are quite small, but I think it is doable on the plasma
If not, I can try to have my buddy laser em at our robotics shop.
Any way you can help would be awesome! Would be cheaper to get someone here to do it than go to a machinist probably
Yes, fer sure. Most machine shops wonât even take small jobs like this, or will charge an insane minimum.
Send over the file, and I will see what I can do
I will send it through once I get the file. Gear is still going through testing to determine whether it will be usable and compatible with the hardware we are working with. Iâll get back to you, cheers legend
Awesome. Just let me know!
just wondering, bro, if youâre capable of machining (lathe) some CroMo axles? maybe 10ish?
do you have access to 1/2" dia. CroMo rod?
pretty simple machining just step down the 1/2" rod to 10mm and add some threadsâŚ
Sorry, I wish I could help, sadly I do not have access to a lathe right now (corona
I will ask around and see if I can find anything. Send me a PM pls.
Canât promise anything, but I will see.
thanks⌠I can do it myself⌠but the lathe I use is corona-locked-up, and a friend can do it for me in Az. but shipping etc.
thanks just asking for a friend!
i left this out on purpose because i have to finish the design myself anyway so i wanted to give a easy model that does not have to be flipped. And no need to add one fillet while having to do the other by hand
so this was my choice, not his finish.
Impressed dude. When I was 15 I was running around trying to get my finger stinky and thieving Budweiserâs from the neighbor. Keep it up and youâre going somewhere. Props.
thanks for the kind words!
