parallel chargers are iffy. but you can always try it. Hook chargers in parallel without anything else. just positive to positive and negative to negative. if the lights stay red when its just the chargers in parallel then theres no current flowing from one charger into another. problem is, if there is an issue, itll probably damage one of the chargers
and these are 12 supplies in series. not parallel.
For the lights, does this diagram indicate I wonāt need a step down transformer / converter? Iām looking into how to light my board at the moment, and Iāve read Iāll need some type of way to step the voltage on the battery down to something acceptable to the LEDs⦠Does the BMS handle that? Iāve ordered this BMS for my 12S battery: Smart BMS ā 12S ā esk8Life and plan to bypass the discharge component of it. Thanks!
There are many ways to add lighting, some need a step down and some donāt. Most do. Itās highly specific on exactly which lights, how theyāre connected, what your battery voltage is, what you want to achieve, how failures are handled, et cetera
This is a good question. On a charge only balance wiring, can you set up output current limits within a Smart BMS to (reliably) output say 5V for an Arduino or 12V to directly power a string of LEDs from the P-?
