No worries, not a fail, this stuff is not easy!
Just got the exact bushings you recommended (93a Krank riptide barrels) with flat washers in the front, two cups in the rear. The stability is amazing. I think my board is perfect (for now) might want to experiment and try different things in the future.
My board behaves just the way I asked for. I can only turn “easily” when going 20 kmh/h+ at lower speeds than that it is stiff like a plank
but that is great. I don’t mind putting my whole body into it when turning at lower speeds. Really what I was after is being able to just put on full safety gear and blast off to work at 40 km/h and this will be great for that.
This setup also gives me some room for experimentation. I can change out the rear for flats and loosen the front a bit if I want to turn more. Before I just had my board as stiff as I could get it…
I even bent one of my flat washers somehow from the pressure
had to use both hands and my feet to the rear bushings off, and they looked nasty. This time I will not need to over tighten
Try the experiment in riding Front Wheel Drive - you’ll be even more blown away.
No harm trying as only the Revel Kit has this ability to. Other DIY setups would be a real hassle. But flip the front bushings to become the rear ones if you do go ahead to try
Hey I have a Boardnamics 220mm hanger + Caliber Baseplates (50D) set up on a 40" Hummie Deck and currently need some bushings for it, I need a setup that will do 40+ mph but still carve well, I’m a pretty light person weighing in at 125 LB’s, what would you recommend for the rear and front trucks, I also need some washers to go along with that
@AlanZhou, 50 degrees front and back and you want to go 40+ MPH? How much skating experience do you have?
36+ on a lacroix, 44+ on a uni (not sure if this counts
), 35 on a craptor
That is not much for me to go on. It takes a lot of experience to safely and consistently go 40+ on a 50 degree symmetrical setup.
the raptor felt slow at 35mph on a 50/50 setup super stable, im not really worried about wobbles that much.
Held around 34mph on my hummie’s 195 paris 50/50 91a bushing’s stable for around 3/4 of a mile
OK, I am going to suggest a plush setup, all KranK 87a : Canon / FatCone front and Canon / Chubby for the back. This should get you where you want to be.
Thanks! will be ordering soon.
If you do not want extra bushings, just order a pair of Canons and Chubbys and leave a note on the order to make the Chubby pair a mix of a FatCone and a Chubby
Done, ordered
thanks for the help
Are you sure it went through?
I am guessing you tried this. What difference does it make? I have tried it without adjusting bushings (obviously not ideal).
You make me curious, but I would like to know what to expect.
Insane stability at high speeds, if you let go of the throttle at high speed at neutral, there wont be any hint of speed wobbles normally associated with a sudden drop in acceleration with rear mounted motors
There’s a whole thread on this subject and we should head over there as this is off topic to this thread - Front Wheel Drive Discussion
Yup. Order #19600
OK thanks, found it. Normally I receive notification but I found it in the system! Will ship today.
Hi!
I’ve got a 40 inch Kracked Skulls Scimitar with Caliber 2 184mm 50 degree trucks on half inch risers and stock bushings (89a). I weigh 155 and am 6 feet tall.
I think I got the board in 2016 so the bushings are now terrifyingly soft. I want to massively improve stability especially at speed. I’m getting ridiculous speed wobbles whenever I let off the power on the esk8, kind of like lift off over-steer in a car. I’ve been thinking about running wedges to reduce the angle of my rear truck and increase the angle of the front trucks.
Thoughts?
Also, thank you so much for helping!
OK, @richcriminal are you top mounting or dropthrough mounting it? As for wedging and de-wedging, it will be much easier to do top mounted and I would use a flat riser up front (50 degrees turns enough) and de-wedge the rear at least 10 degrees.
Top mounted currently.
