Got the dimensions and pictures/information you asked for here. Thanks in advance ![]()
Wish you told me this before you unloaded then on me
I read above that these trucks donāt allow a kingpin replacement. Or am I wrong
Any detrimental effects of me cutting a mm off each riptide bushings. Cannon and kranks
I need more thread grab.
Also, these might be too tight of durometer⦠itās stable as fuck, but I miss that carving sound and feeling.
Hey @RipTideSports:
Iāve been looking today for the best source for some nice hard 95a, 97a or harder barrel bushings. I have some red 95a riptides and I like them.
But I want to replace the bushings on a half dozen boards and build a few more. The retail stores are closed down due to covid and I find the online prices pretty high by the time you factor in shiping. Also, there are not a lot of good options for purchasing bulk.
I found a few bulk options but they are unfamiliar and they could be really crappy.
This seemed like a good deal, but I donāt know if Saber is a reputable brand.
Iām thinking about ordering some Alibaba samples. But they could also be crap.
So how do I order a bulk batch of Riptide bushings that I already know that I like?
95a, 97a or harder if you have them. If the price was right, I would purchase a dozen, maybey two dozen.
alibaba bushings
Sabre bushings are poured in the US
Gotta get the short street
OK @Fromualdez for a 50/35 split using TB 218 hangers, I would suggest Canons up front and a Canon / Magnum rear, all in KranK 90a. Have some cupped washers available to fine tune the Canons with. You should pick up some agility and not sacrifice stability with this setup. Pick up 2 pair of Canons and one pair of Magnums so you have some options to play with. Canon /Canon front, Canon / Magnum rear, Canon /Canon front, Magnum / Magnum rear
From what I can tell of what you have shown, the main benefit is cosmetic
First @BearBoi, stop over-tightening your bushings, it does not suit you :). Your trucks appear to be Paris clones so we will assume they will fit the same bushings as Paris based on your dimensions namely Canons and Magnums. Do you have any idea what durometer the stock bushings are and what is your weight?
What trucks are these Kevin? Have you tried ditching the boardside washer for more clearance and to get less resistance, use the larger bushing roadside and the smaller bushing boardside. No harm in cutting down bushings as long as it does not adversely effect the geometry of the trucks.
Do you still have the stock bushings? If I remember correctly they take .4" on top and .6" on the bottom
Bushing for Kahua trucks
More accurately
(0.51" and 0.59")
Solution Gotta get the short street
get this for street side
Iām curious how often do you develop new products? Is there a chance you would make a ~13mm barrel size? Not sure itās really necessary.
@RipTideSports this info was a general guide on Kahua trucks for @kevingraehl and others
I also misunderstood what you were saying with the measurements, you were talking about what size of your bushings fit.
Thanks so much! Just to confirm, these are tall bushings? I was looking at your website and the Krank canons give two different measurements for height; the picture states .60 inches, but the description states .75 inches. My apologies for not stating my need for tall bushings.
OK so with the different base plates they take tall top and bottom?
This is really confusing, sorry, you need to keep it simple for meā¦
Yes, I need four tall bushings. Thanks again.
I would suggest TallBarrels / TallFatCone front and a TallBarrel / TallChubby rear, all in KranK 93a. Have some cupped washers and flats available to fine tune the TallBarrels with. You should pick up some agility and not sacrifice stability with this setup. Pick up 1 pair of TallBarrels and a mixed pair of a TallFatCone and a TallChubby. To get the mixed pair just order a pair of KranK
TallChubbys and ask us to make it a mixed pair with a TallFatCone.
OK @pkasanda, this is kind of a delicate subject based on our business structure. The only people we sell bulk bushings to are our OEM accounts like Donāt Trip, BioBoards, G-Bomb, Voxter, Alsen, etc so we are not planing on going there at this time for non-OEM accounts. I am sorry the only kit we do is for TKPās and the only reason we do that one is to get people to try new shapes in their street trucks. We do not want undercut or offend our retailer network either by offering bulk packs at a discounted price in addition, we frown on our retailers discounting RipTide so it would be hypocritical if we did so. Sorry such a long answer for saying we do not do what you are asking for. The bottom line is we want to support our brick and motor shops as they are having a tough enough time as it is.
As for the Saber pack, I do not have any opinion on what they make and I have little confidence on what you will receive from a commodity supplier on Alibaba. I wish I could have been more helpful.
