Kingpin is flipped, so it’s inward mounting you have to worry about xD
These TKP versions are a limited run
Because it’s TKP, the clearance issues would be in front mounting. Reverse mounting is allowed and preferable.
Cool to see this! This may make me try tpk…
29T motor gears being made, increasing the ratio to 2.20 for those who love speed
Helical gears also coming ETA 1 month perhaps
We shall pray to the shipping gods
what ratio will the helicals be?
60T/22T. Tried by best to make it the same but it’s impossible since helical gear teeth are a little bigger.
Have you tested the helicals?
Samples come in real soon
What’s the max ratio you could put on the straight cuts?
Does a smaller gear ratio increase speed and decrease torque? I heard it was an inverse relationship like that but wasn’t sure
Technically 64T/31T but that seemed a bit extreme.
My bad. I meant min but yeah, that’s pretty extreme.
That would be the way it is now; 64T/23T
If you need a beta tester, I’m your man
You or @KaramQ the master at breaking my products by not tightening set screws, then having them party in the gear box until they jammed the gears, sending him flying
Bahaha you know it
I take it this happened recently lmao
