Love the prime numbers
#metoo
Good for the tooth wear. :sunglasses:
alright I better find myself a torch to use. I emailed about adding the new axles to my order in progress.
Anyone got a good source for 10mm bearings?
How? :sob: Why can’t I just put it on the same fivestar hub as my 8inch? Why must something need to change?
I would assume it is because of the extra step on the AT type trucks. It changes the spacing
Is this just for the boardnamics trucks? I want to use 9s on matrix ii
That’s fine then, I will ship with what spacers are required.
Wait am I confused here? Are you talking about fitting 220mm tires or using the BN 220mm axle? I won’t have a problem using M1 AT with matrix ii trucks and 225mm (9inch) mbs t2 tires with fivestar hubs and also mbs t3 200mm (8inch) tires?
I didn’t see the first message :sweat_smile: I was confused about why 9inch tires would be a problem. Thanks
I’m curious, what gear ratio are people choosing for their M1-ATs?
I’ve no mtb experience. Is it like 5.20 == torquey, 4.60 == balanced, 3.95== speed? (ignoring all the other variables of course)
How much do you weigh and what size tires?
I’m going 3.95 on superstars metr155 I’m 235lb on a good day :rofl: i’m a little hesitant I might upgrade to 4.6 but definitely not 5.2 I want a little torque but not mountain climbing torque
I like to put in the calculator all the variables including a standard kv like 190 and from then find the gear ratio that meets the top speed you wanna reach.
I think that is the general idea?
I can tell you this, like I just said to @Paul77
I ride my bergs street board pretty hard and this has WAY more torque than that. My street hummie is 15:40 ratio on 145mm wheels with 190kv motors.
Sure, but that doesn’t give any indication of how quickly you’ll reach that top speed.
The 3dservisas calc gives a torque value, but I have no context for what’s strong/weak.
Let’s say 200lbs / 90kg and 200mm / 8in tires. I’m still unclear on how to balance motor kv vs gear ratio vs battery voltage. It’s a multi-variable equation!
Edit: generic setups
#1 [Balanced A]
Battery - 12S (43.2V nom)
Motor - 170 kV
Tires - 200mm
Gears - 4.6
Avg Loaded Speed: 33.6 mph / 54 kmh
Max Torque: 22.7 ftlbs / 30.8 Nm
*this works out the same if you choose 190 kV and 5.2 gear ratio. interesting.
#2 [Balanced B]
Motor - 170 kV
Tires - 200mm
Gears - 5.2
Avg Loaded Speed: 29.8 mph / 48 kmh
Max Torque: 25.6 ftlbs / 34.7 Nm
#3 - [Max Torque]
Motor - 140 kV
Tires - 200mm
Gears - 5.2
Avg Loaded Speed: 24.6 mph / 40 kmh
Max Torque: 31.1 ftlbs / 42.1 Nm
#4 - [Max Speed]
Motor - 170 kV
Tires - 200mm
Gears - 3.96
Avg Loaded Speed: 39.2 mph / 63 kmh
Max Torque: 19.5 ftlbs / 26.4 Nm
Per https://calc.3dservisas.eu with default efficiencies, power consumption, etc
Still curious if anyone can put a quantitative value to SUPER TORQUEY
@ShutterShock , what size tires are you running on your setup?
I went with 140kv and 5.2:1 because I’m building a 16s so that’s gonna push the max speed way higher than what I need and this configuration will lower the speed the most and give me the most torque (something like 60kph/38mph for 9inch tires)
Yeah if you go higher voltage that makes all the diff. I’m only on 12s so I’m more limited in that regard. I think mine will max out at 33 loaded right now, but since I picked the highest, I suppose I can always upgrade to 16s later if I wanted
I’m running 8 inch MBS T1’s
No idea haha, we would need qualitative data like how fast acceleration to 20mph is or something
True, I guess experience is a big helper with this. I tried 3:1 with 6" tires which for me didn’t have enough torque even with 130kv. Also tried 4.8 with 7" tires and I was pretty happy with plenty of torque.
Personally I would consider this a reasonable setup with 12S:
At least
4 with 6"
4.5 with 7"
5 with 8"
Assuming 190kv and 12S one will probably have enough torque if the top speed stays under 50-60 km/h. This is not based on exact math, just from trying with a sample of 4 different setups.
