Did you do the Lou deck with the front wheels drive? Did you have 80s or 85mm
Anyone have an opinion on whether I should build this switchblade with m1 helicals, or BNs idler system?
I was leaning towards the belts because I can mount them reversed and have a bit more clearance for going down curbs or going to a pump track. Iâd love to hear what you guys prefer though.
I kinda want to mount some rollers on my XL mounts because they be knocking on hella stuff. Tiny little skate wheels would be good.
Iâll scrape down curbs, my driveway, blah blah. Maybe weâre too low? I just need that urethane range thoughâŚ
what u need is some unobtainium
Any updates on the new Shipment with everything restocked and new? How long till youâll be Able to have pending orders completed? Canât wait to get my gears and ride.
Ship is being unloaded. 99% sure next week I can ship out everything.
I have prepared everything so when I get the stuff, I can immediately get to work fulfilling.
Idk if anyone responded to this but be sure to set your motor pole pairs correctly. 14 pole motor = 7 pole pairs for example.
Hey @Boardnamics I would like to buy 2 64T gears and maybe the upgraded berg adapters (as Iâve heard the old ones have problems) itâs that possible? How much would it be?
I want to have my gear always ready so i can switch between wheels as fast as possible!!
Teflon / PTFE / UHMW guard sliders brooo
Edit: McMasterCarr 9928K61/Slippery UHMW Polyethylene U-Channel
Anyone Try the 2.20 faster ratio with the gears? Howâs the torque on them?
Iâd only get the 2.20 ratio if youâve got 6374s, my 6354s with the 2.20 ratio doesnât feel like enough torque IMO, but that depends on your esk8 experience of course.
Oh youâre the man, gonna pick some of those up.
There should be no difference in torque between 6355 and 6374 at the same settings.
If they were lower kv motors, try the lower ratio
I am running 6374s, I want the speed ratio because I want something more powerful as far as speed than any of my other builds which already achive 30mph, I just donât want to sacrifice to much acceleration and breaking power just for high end speed.
Did you ever get to test this? Need to know if I should go and buy some spacers
Not yet, donât have the motors on hand. If it tests well, I will provide the spacers.
Has anyone ever had a gear tooth brake in their m1?
- I have personally broken plastic/polymer esk8 gears made by not-Boardnamics
- I have personally broken steel esk8 gears made by not-Boardnamics
- I have personally broken steel esk8 gears made by Boardnamics
- I have personally broken non-steel metal esk8 gears
- I havenât personally broken any esk8 gears
- I havenât personally used gears on an esk8
0 voters
