@Boardnamics Kevin dude? This is not closely guarded IP it’s 2 angles come on!
More toys on the bar = more sales
I’m no alcoholic but this sounds about right
After discussing with my board of directors, we have decided to give out this top secret IP. This message will self destruct in 24 hours.
Thanks I’m whistling the correct top secret tune now
Anyone know if I can put the 270s with pneumatic wheels on a Switchblade deck (10" wide) without getting wheelbite? I’ve seen the longest Surfrodz config bite with 6" wheels, and I’m hoping on putting 8" Rockstars potentially without needing to move the mounting holes.
I am not 100% sure, but most likely yes. If they are not enough for it, you can get wheelbase extenders from @IDEA
Just search for Aluminum dropdown bracket on the forum and you will find the solution. Most likely these hangers will be enough tho.
I would be interested whether they can fit as well. I have the same deck and I am planning to use 6 inch tires next year. With an adjustable baseplate matrix II setup they would fit for sure, but thats not exactly cheap, so I would rather go for the 270 hangers if they are enough.
I want to avoid moving the mounting holes if possible, since it would put more pressure on the forks because the lever arm is longer. If it were a platform top mount I’d be ok with it, but with a double drop I have questions on durability.
This is the topic I meant. about reply 120 is where idea appears
I did attempt to fabricate my own, but i couldn’t get the holes neat enough drilling by hand.
You can get a professional billet machined aluminum skateboard hole pattern drill.
Lot of money for a small block of aluminum with holes
Boardnamics Skateboard Hole Jig $12.99
Do it
Great. @Boardnamics hole pattern drill jig wasn’t available half hour ago
. That’s why you need competition. Increase creativity and lower the costs.
@Boardnamics, now go fabricate a bunch, call deck manufacturers and DIYers and sell the drill jigs.
nice one! I’m gonna get my cnc dude to cut me one
Maybe just use a riser pad
Print out template 1:1 stick on deck, drill holes. 2 cents
Print out 2, able to compare straightness. 4 cents
I must have this.
PM sent
One hole is smaller than the others?
good eye.
