Will do, i have an appointment with a Esk8-electrician-battery-builder soon who was talking about a way to measure current while charging ![]()
Can someone tell me what actual benefits I get form a smart BMS compered to a normal on? Considering I will be running the thing charge only! I now have this Daly
What would i gain safety wise other than seeing at what voltage my P groups are?
My battery pack is a 10s3P from Molicel P26A
I wanna revive this to ask: what’s the go-to smart BMS these days
If you are willing to pay the premium, go for a smart BMS w/ Bluetooth connectivity. I do not trust any of the passive/non-IC BMS. Being able to monitor every parallel on-demand gives me to confidence to keep using my pack. I am currently using an LLT BMS 12s 60A which does all that and I am quite happy about it. My only complaint is the thick form factor because of the heatsinks.
LLT bms
Speaking of LLT, does it come with a hw fuel gauge or is the ah usage a digital estimate?
is this what I would want for a 14s setup? sorry, very new to all this – just looking into a smart BMS for my builder to use instead of the basic one
u don’t need the 120a version unless u don’t plan on running bypass discharge, usually people just go with this one:
If you know what your doing w/ the rest of the electronics, any of their Bluetooth BMS lineup with a sufficient amp ceiling will do just fine electronically.
don’t think u can get that info unless u wire it as bms discharge
for a 14s8p setup, I assume 60a is sufficient?
I personally don’t bypass the BMS because I like the discharge protection.
Here wait, you’re not using a 60v VESC on that r u? If you’re going to use charge only, the minimum discharge current will be fine(cause you won’t be discharging at all).
using a ubox v1, honestly can’t remember the voltage… but yeah planning to bypass discharge anyhow
Ok, the 14s 30a version should serve you fine.
14s you mean yeah? and only 30a?
Oops, yes 14s. Unless you’re going to charge above 30a, yes.
Do I need a 75v BMS for use with the ubox v1? it’s 75v…
that’s the charging current, surely u r not fast charging with more than 30a?
no
