Damnit. DRV fault on the remaining focbox. ???
first 0.5 km of the day.
No idea if this is related to the first problem but continuing here because it’s suspect. board triggered a very similar feeling problem a cutout with the funny noise and then some drag. got home and found DRV fault on the secondary focbox.
No faults registered since startup
The following faults were registered since start:
Fault : FAULT_CODE_DRV
Current : 150.5
Current filtered : -33.7
Voltage : 36.39
Duty : 0.753
RPM : 33796.9
Tacho : 171975
Cycles running : 99717
TIM duty : 6326
TIM val samp : 2
TIM current samp : 4200
TIM top : 8400
Comm step : 0
Temperature : 43.39
I have zero clues at the moment what a DRV fault is and what causes it.
METR did not seem to pick up this fault though. I think it’s supposed to pick up faults from the secondary over CAN at this point. I think I’ve seen it do this. but it didn’t.
here’s the record from it happening.
