All of them. Initially mad wheels, then I’ll probably try my treated and untreated abec 107s, and once they are shipped my guess is hollow wheels comfort v2.
I call shenanigans. How do you plan to run Hoyt 125mm? What about other pneumies? You plan to run Kegel and abec cores? What is this sorcery you speak of?
My plan was to use BN220s with m1 gear drives, and 6370s. Turns out 6370s only fit on a BN220 when reverse mounted. It also turned out that reverse mounting is impossible with the vanguard enclosure. Unless you run at the highest angle BN adjustable baseplates support, or use many risers.
The solution: I acquired a single BN270 which will be here Tuesday.
Today I pulled the bearings from my Kegel adapters, so i can replace them with 10mm ID bearings.
BN m1 drives are incompatible with the vanguard 42” eboosted enclosure if you use 6374 or larger motors.
I have tried both 220mm and 270mm BN hangers, both only allow reverse mount of motors. Reverse mounting is incompatible with both front and back of the enclosure. The 270s might allow a standard mounting if you use the straight cut gears which i beloved are larger, but I don’t know. With the helicals the can hits the hanger before the teeth engage.
It might be possible to make the 270s work in a standard mount if you grind away the ridge on the hanger.
It’s possible to reverse mount with both hangers at the highest angle BN adjustable bases plates go. Needless to say I don’t consider setting my rear base plate to an absurdly dangerous angle a solution.
